Wth
Old Jan 3, 2014 | 10:20 AM
MidnightTheSS's Avatar
Wth
P0650 - GM
Type Powertrain - Computer and Auxiliary Outputs - ISO/SAE Controlled
Description
Malfunction Indicator Lamp Circuit Conditions
Cause
Key on or engine running, system voltage from 8-16v, then the PCM detected an improper voltage level on the ODM 'D' output 1 circuit, condition met for at least 30 seconds.
Old Jan 3, 2014 | 10:36 AM
BlackielawlessSS's Avatar
Old Jan 3, 2014 | 10:42 AM
THEMISSLE's Avatar
Description: DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit
Conditions for setting DTC: The control module detects that the commanded state of the MIL driver and the actual state of the control circuit do not match for 12 seconds.
Check your MIL circuit from your PCM to your IPC for a short to ground or short to voltage. If the wiring is ok its either a PCM or IPC internal issue
c0baltsssc06
Jan 25, 2010 11:30 AM
leingod
Jan 23, 2010 11:14 AM
c0baltsssc06
Nov 23, 2009 01:44 PM
SmokinSamSC06
Dec 26, 2008 11:41 PM
