XM Radio help
XM Radio help
Got the car like 4 days ago.
Yesterday something weird happened after I set some favorites for radio stations.
When I select "Band" and then select "XM Radio" and select "CAT" for catagory's, it would say on the top viewscreen "XM CAT" and right below it is still my radio station presets, I don't get to see my the catagory's like "Dance, rock, decade, etc.... However, some of my preset favorites are XM stations and can still select them.
WHen I turn the ignition off and back on I was able to select Catagory's again. However, when I select "Favorites" and then click on Catagory's afterwards I was back to square one again.
I'm having XM problems, too.
Just so you know, though, you dont' have to cycle the 'band' to select categories. As long as you aren't using cd/aux you can select Cat. Also your presets can be intermingled, you can have XM, AM and FM presets all under the same favorites listing.
There's a setting where you can reset your categories, you may want to try doing that - i think it's under the "i".. Aside from that, take it to the dealer :|.
agentirons
Oct 16, 2015 02:11 AM
shawnsseries
Sep 10, 2015 08:29 PM
