you give me your opinion
All right well this is my issue. I took my car to the dealer for a.master.cylinder replacement. While the tech was working on the car he broke my clutch pedal. So I got my car back with my pedal broke and a no start situation. I called the gm reps.out here and they said it would take up to two weeks to fix my car becuz they wanted the dealer to tell them there story
So i replaced the clutch pedal assembly and adjusted ny zzp adjustable clutch rod for optimal performance and I still couldnt put into gear barely. So I bled the system more then 20 times. I gravity bled it, the old way, and I vacuum bled it. The clutch pedal is stiff but.not as.stiff.as before the master cylinder went out. I checked for air bubbles from the. Master cylinderr and its working a 100% so I rebled the system and same issue. The throwout bearing is engaging but it looks like its not all the way. The car is a 2009 ss/tc with all hahn bolt ons a clutchmasters stage 4 clutch and a new master cylinder . I've ordered a new master cylinder from ced befuz im,about 99.50% poitive this is my issue. Im not leaking fluid but i think that the slave cylinder is giving out. Just want your opinions about wut u think it is. Ill keep u updated. Since i got the car all its been is a problem.........
another thing is when u have the car started and try to put it into gear its.like a wall it will not even budge.... if u have the clutch pushed to thr floor and in gear and start the car, it'll move and start... errrrrrrrrrrr
Thanks guys
james
Thanks guys
james
Oh noo yeah sorry bout the typos it was on my phone last night. Actually my ss/tc is the car thats fucked, its hot full bolt ons, and so forth..... i am doing all the work. The dealership are the ones that broke the ****, and after they broke it, they said they will not work on the car any longer ....... So i have to fix it myself while getting a lawyer so i can Get a lawsuit against them.
yeah true true. The tech that broke it is a high school kid that works at the dealership as as class basically, has no ase'z no certifications to work on trannys or clutches either and he admitted to the owner of the dealership and the service advisor that he broke the stuff. But they are now saying that it was broke already and the stupid tech (Kid) Has been spreading the rumors that he broke my car lol. kinda lame right?
usually if air is in any system the pedal would be soft, not hard. Idk, I can check my automotive trans books, but I don't like reading good luck! that would totally **** me off.
2009 tc.with clutchmasters stage 4 my master.cylinder went so the dealership replaced it. The car was fine but still hard to ge into gear ecspecislly.if.I.drove.it.for some.time.and tried.to change. Gears... the.lines are.bled correctly and the pedal pressure.in not as tough as it was used to be. I looked at the throwout bearing while.my friend .pushed The. Clutch pedal down and it seemed like it didn't.move.enough... hope that helps
Thanks
Thanks
importkiller
09-30-2015 07:18 PM
