R1 Concepts R1 Concepts is a Supporting Vendor.
Contacts: r1concepts
R1 Concepts Premium Rotors - limited time GroupBuy!
Old Nov 19, 2009 | 02:41 PM
  #101
r1concepts's Avatar
Originally Posted by irishredheadpa
when is the group buy over? and i need a price quote for Front and rear drilled and sloted with hawk hps pads, thanks
Originally Posted by agitator
R1, which one is the best with the hawk hps? i just need 2 front rotors for now.. pm me a price
All sent, thanks guys.
Old Dec 2, 2009 | 03:51 AM
  #102
gomedan1's Avatar
is this deal still goin on
Old Dec 2, 2009 | 01:31 PM
  #103
Hyperpred's Avatar
Hey R1 wanted to say thanks for the rotors. they came in handy last night. I was in Chicago and on the dan ryan (anyone from around here knows how this ends already) and someone in a mini cooper cut me off because they forgot they needed to exit right NOW and were in the far left lane. Well the guy in front of him slammed his brakes which caused the cooper to as well. And so I had to stomp the brakes... They definitely stopped me in a hurry. Just another bump for these rotors/pads
Old Dec 2, 2009 | 02:00 PM
  #104
r1concepts's Avatar
Yes it is.
That is real good to hear nothing happen to you or the car. Thanks
Old Dec 4, 2009 | 10:04 PM
  #105
cobaltss86's Avatar
damn i need these bad i think im gona need to invest but after the holiday like in january do you think it will still be going on then?
Old Dec 7, 2009 | 06:15 PM
  #106
r1concepts's Avatar
I think you should be fine, Just pm me and I'll remember if anything changes.
Old Mar 6, 2010 | 03:13 PM
  #107
cobaltss86's Avatar
i sent a pm im ready to buy
Old Mar 17, 2010 | 03:11 AM
  #108
06CobaltSS635SC's Avatar
so are the premiums worth the money over the Eline rotors these guys have? Looking to get Slotted and Drilled, not gonna spend extra $$ for the Premiums if they are just as good as the Elines. Thanx!
Old Mar 17, 2010 | 05:54 AM
  #109
Jordonias's Avatar
Wondering the same. Want to order this tomorrow if the GB is still available.
Old Mar 17, 2010 | 07:43 AM
  #110
CudaJoe's Avatar
I love the premium rotors... as far as I see its a great buy no matter how you slice it. I dont think I'd drill the rotors though. just a suggestion.
Old Mar 17, 2010 | 02:35 PM
  #111
r1concepts's Avatar
We offer two different series of rotors (will be having three soon, in the makings). My stage one rotors are my E-line series rotors. Those are the ones that come dipped entirely in silver zinc platting which is a rust protection coating and standard iron cast g3000 metal material like your originals. E-line rotors are the same size diameters as your originals. I also carry a second stage which is the Premium series rotors made with an even stronger iron cast graded metallurgy and comes with a black E-coat rust protection coating applied on the center hub and inner vane structure and outer rim of rotor. Premium rotors have better air flow because they are built with a 50/50 center split vane structure design (some also comes curved vane and columned) for efficient air distribution to try to eliminate heat spots. Premium rotors are stronger than the E-lines and also same diameters as originals, direct bolt on. Both series comes with double disc grinding surface which leaves a non-directional finish on the friction surface area for more effective pad-rotor break in. This helps for quieter and smoother stops (non - drilled).
Old Mar 19, 2010 | 06:46 PM
  #112
Fidget's Avatar
Just as a testimonial i purchased my second set of rotors and pads from R1C. I got over 60,000 miles on my first set until it started to warp. The product is great and worth the price.
DANRICKARD
Oct 1, 2015 12:08 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
