Window trim cleaning
what do you guys use to clean the window trim on your car? mine is starting to become a little dull looking and has dried up water spots. also the plastic piece on the bottom of the window has so much grime on it that its starting to turn white. ive tried just washing all the trim but it does nothing. any input is greatly appreciated.
I think you should use the professional squeegees, soap and applicators for windows cleaning. Don't clean windows in direct sunlight. Exterior windows should be first be washed with a hose or clean water to remove grease and grime.
