LNF SS/TC Brembo Calipers Part Numbers?
Old Dec 25, 2008 | 11:16 PM
  #126
Maven's Avatar
Originally Posted by FunkyStickman
Har har.
I was more specifically talking about some of the things that were suggested, but I don't recall seeing a definitive answer about. If I've ready correctly, the only parts that need to be swapped out are the actual calipers and bolts, pads, and rotors? The brake lines were confirmed to be the same? And besides needing more spoke clearance, it's a 100% compatible with LE3 and regular LE5 setups...
If that's the case, then I will most likely be looking into doing this swap down the road as well (no pun intended). Doing a full FE5 conversion will be first on the list, however.
The brake hoses are NOT the same, but they are serviceable.
YES all you need is the brake parts, and if you decided you needed the hoses so you were legit, they are only like $30, you should be upgrading to braided stainless anyway.
Old Dec 25, 2008 | 11:20 PM
  #127
FunkyStickman's Avatar
Fantastic man, that's what I needed to know. Excellent!
I'd tell what I'm considering this swap for, but then I'd have to kill you...
Just kidding. Guys like you prove that CSS.net isn't a total loss after all. Thanks again.
Old Dec 25, 2008 | 11:44 PM
  #128
Maven's Avatar
Ummmmm an Ion?
No problem. If its not an Ion, It better be worthy of Brembos
Old Dec 30, 2008 | 11:12 AM
  #129
Ummmmm an Ion?
Wasn't quite what I meant... I was talking about what I am planning to do with the Ion after I do this...
Regardless, thanks again. I don't know of any Ion guys that have done this yet, so maybe I'll be the first.
Old Dec 30, 2008 | 12:23 PM
  #130
Maven's Avatar
Ah...youve got secret plans for the Ion, I see.
If you wanna be first you need to hurry, I know of another IRL thats getting the same treatment.
Old Jan 3, 2009 | 03:46 PM
  #131
Doward's Avatar
So what kind of price is this?
Need the pads / rotors / calipers, and that is it, correct? I need to do a brake job on my wife's '05 IRL Comp package anyway - I'll go ahead and throw down on new Brembos
Old Jan 4, 2009 | 02:05 AM
  #132
Maven's Avatar
pads, rotors, calipers, pin kit, and should get hoses. wheels too fit. All this information is in this thread and several others, take a peek around
Old Feb 6, 2009 | 10:38 PM
  #133
mike25's Avatar
from what i gather your looking at about700-800 maybe at the most for fronts. not too bad really
Old Feb 7, 2009 | 01:51 AM
  #134
Maven's Avatar
No, youre looking mid to high 800's for fronts, still super hard to even come close unless your willing to actually buy brakes and not just a name or pretty anodizing
Old Feb 7, 2009 | 10:45 AM
  #135
mike25's Avatar
yea i just guessed mainly after checking the part numbers. i considered this, but ill probably still just go with slotted drilled dbas and some high perf pads
Old Feb 7, 2009 | 11:27 AM
  #136
Maven's Avatar
Unless youre 100% sure that this will fit with your wheels, its not really worth it imo, most people would be amazed at what GOOD pads, rotors, fresh fluid and teflon hoses will do for performance
Old Feb 7, 2009 | 11:30 AM
  #137
mike25's Avatar
thats what im mainly worried about. i just bought aftermarket enkei's that CLAIM the brembos will fit but im not sure its worth risking. im looking at dba's and carbon hawk pads for the time being, so im hoping they will deliever some top notch performance.
Old Feb 17, 2009 | 10:40 PM
  #138
mike25's Avatar
btw i just priced out both front rotors, calipers/ a pin kit, and all new front pads for 756.49. im not sure if the washers come in the pin kit or not, however i dont think itl throw it up that much, which still is under 800, and not bad at all imo.
Old Feb 18, 2009 | 01:17 PM
  #139
Maven's Avatar
You need two pin kits.
Old Feb 20, 2009 | 09:13 PM
  #140
mike25's Avatar
lol. 775.26
Old Feb 20, 2009 | 11:35 PM
  #141
Maven's Avatar
lol. 775.26
Yeah I know, they are an awesome deal, thats why Ive been talking about them for monthsssssssssssssssssssss
Old Feb 21, 2009 | 01:43 AM
  #142
spike's Avatar
how much better would they be over ss\sc fronts with slotted rotors, ss lines, and hawk pads?
Old Feb 21, 2009 | 11:54 AM
  #143
Maven's Avatar
Eleventeen hundred.
If you think think Hawk HPS pads are the penultimate brake pad then the Brembos will blow your mind.
Old Feb 21, 2009 | 12:19 PM
  #144
spike's Avatar
i been looking but still havent found anything yet..... r there sloted rotor yet for the brembos and upgraded pads?
Old Feb 21, 2009 | 12:26 PM
  #145
ls1fbody's Avatar
Haz l33t wheelz.
Eleventeen hundred.
lol, i'm pumped than. are the OEM pads good enough to be better than the upgrades available for the stock SS/SC stuff?
Old Feb 21, 2009 | 01:09 PM
  #146
Maven's Avatar
No, there are no aftermarket rotors for the SS/TC brakes that I am aware at this time.
There are aftermarket pads, but i wouldnt call all of them upgrades.
The OEM pads on the SS/TC brakes are a very serious pad. They are Ferodo HP1000's. This is essentially the most aggressive street pad used by ANY manufacturer. Google that pad name and see what other vehicles its used on.....then you tell me if its enough for a Balt.
I would consider EBC Reds, Hawk HPS, Axxis, Posiquiets, etc, etc, etc(virtually every pad youve ever seen used widely here) all a step down from the HP1000's
Old Feb 21, 2009 | 01:48 PM
  #147
mike25's Avatar
i want to do the brembo swap...but i was hoping to find some drilled rotors for them. i may hold off and wait for them to make a set and then do it
Old Feb 21, 2009 | 10:24 PM
  #148
spike's Avatar
Eleventeen hundred.
Yeh i did some looking 2 day at the dealer....and i dont think my wheels will clear.... so im looking at way 2 get around this small problem
Old Feb 22, 2009 | 02:04 AM
  #149
Maven's Avatar
dont be ghey.
Old Feb 22, 2009 | 02:06 AM
  #150
steddy2112's Avatar
Drill your own.
Be 1337 like that.
Or get the BAER kit if you are that worried about having drilled rotors....I believe their BBK is drilled and slotted.
