06 cobalt ss no start
Old 03-11-2018, 08:51 PM
rdmason's Avatar
Angry 06 cobalt ss no start
Okay so a couple days ago we put a new head on the car. everything went on fine and we put everything back on right. We checked the timing and thats good, checked for fuel, air, and spark. Have all of those. It cranks over and sounds like it wants to start but wont. Even replaced the crank position sensor, oil sending unit, and coolant temp. sensor. Any ideas on why it wont start????
Old 03-12-2018, 05:32 PM
Johnny Bliss's Avatar
did you take the timing cover off when putting the chain back on to make sure it was right on the bottom sprocket? it can be off on the bottom and still look right on the cams
also when you put the CPS on you need to be tdc #4
Old 03-13-2018, 11:39 AM
rdmason's Avatar
It needed a new cam sensor. Now the car is overheating and the heat doesn’t work.
Old 03-13-2018, 11:50 AM
exninja's Avatar
Sounds like there is no coolant flow. Either there is a blocked line, thermostat is stuck closed, or the water pump is bad.
Old 03-14-2018, 12:48 PM
Henry3959's Avatar
Or your blowing combustion into the cooling system.
Old 03-15-2018, 06:23 AM
rdmason's Avatar
so I had to take the main coolant hose from the radiator to the head and pour coolant down into the engine until I couldn’t fit anymore and now my heat works and all
Old 03-15-2018, 11:08 AM
Henry3959's Avatar
May have just been a bad air pocket. That's what that little fitting above the upper rad hose on the head is for.
Old 03-15-2018, 11:26 AM
exninja's Avatar
yup, bad bubble. the SC version has a high spot going over the SC snout so that's actually the book way to fill it. For the other engines, squeezing the return line helps get the bubbles out.
Old 03-15-2018, 04:12 PM
when i did the top end on my lsj i filled the head before putting the hose on, after that just kept filling the pressure bottle and it bled itself over a short period of time. i was a little suprised because i've had other pressure bottle engines and they were a pain in the ass
Old 03-15-2018, 04:41 PM
Henry3959's Avatar
Now that my Heat exchanger and Lamanova manifold are both vented to the reservoir, it bleeds its self. Never had a problem with the Radiator not bleeding properly. I wonder of some of the bleed ports are getting plugged. It's not a very big opening.
Old 03-15-2018, 04:52 PM
how did you vent your s/c coolant system to the reservoir?i hate the stock filler neck of the s/c coolant system it keeps blowing out when its hot and sucking some air in.
did you T that overflow line off the filler neck into the hose from the bleeder on the engine coolant?
Old 03-15-2018, 05:01 PM
Henry3959's Avatar
Purchase the Option (B) kit. This pic doesn't show the T I made for both to return back but they are both there now.
Old 03-15-2018, 05:02 PM
oh i see i thought you had somthing thought up that didnt' invovle the option b
i'll probably break down and buy a option b at some point. i'm wanting 60s and a new tune before anything else
Sl0wbaltSS
05-22-2014 09:40 PM
SunburstSS
05-13-2012 01:05 AM
OiangeSS
01-25-2011 02:56 PM
wbrevels
06-14-2010 04:23 PM
firemanfrank
08-05-2008 12:36 PM
Quick Reply: 06 cobalt ss no start
