Site Development and Help Site Discussions, Suggestions, and Help
No Start :(
Old Jun 24, 2012 | 02:40 AM
FamousFoster's Avatar
Thumbs down No Start :(
So went over to buddies house today to finally install catless BadMab downpipe.. Disconnected o2 sensor, took off stocker and installed the BadMab.. went to start up annnd nothing.. Just clicking noise, flashing engine and car locked light with each click. No idea what it is, really doesn't make sense. Talked with Warner, battery voltage was reading fine, nothing else disconnected.. So disconnected ECU, reconnected, waited about 10-15 minutes then got a jump start from buddies V8 turbo diesel, and it started right up..
Well drove it back to my house, and let it set. About four hours later I go out to show a friend the slight difference in sound and same thing. Just clinking and no starts... any help/suggestions are greatly appreciated.
Old Jun 24, 2012 | 12:34 PM
Bump.
Anyone have any ideas..?!
Old Jun 24, 2012 | 12:44 PM
MastaShaKe_88's Avatar
bad connection at the fuse box?? if you have Hids, look at your connection to the fuse bx/battery an make sure its not obstructing anything
Old Jun 24, 2012 | 12:49 PM
No HIDs, just depo gen4s.. I'll check all connections at fuse box right now.
Old Jun 24, 2012 | 12:50 PM
K-Train04RL's Avatar
u ever undo the pos post on the fuse box? crank that down
Old Jun 24, 2012 | 12:59 PM
check at the connections at the battery 2 an if anythin take it to autozone to get tested to see if its bad
Old Jun 24, 2012 | 01:09 PM
Connection from fuse box is good. Batt connections are good as well. That pos terminal is tightened down (wasn't loose at all) and still nothing.. Attempted to start again and same ish, just "click click click click."
Makes no sense... Hmm...
Old Jun 24, 2012 | 01:11 PM
Tested the battery yesterday and it was reading fine. I'll take it to Autozone though, never any start issue prior to DP, so I'm lost.
Old Jun 24, 2012 | 01:16 PM
u say the lock is flashing? thats the passlock, i dont know how you would have triggered that. but there is a relearn procedure. not sure if its the same as it was for my 04 redline or not. but put key to key on engine off for ten mins, and then off and then repeat 2 more times (3 in total) and u shoudl be able to go. i had do the relearn when switching my ign switch.
but it also shoyuld not be able to be jumped if the pass lock has been triggered as this is part of your security systems
Last edited by K-Train04RL; Jun 24, 2012 at 01:16 PM. Reason: Automerged Doublepost
Old Jun 24, 2012 | 01:23 PM
All the usual lights come on with key in ignition. Only when I goto start the engine light and car locked lights flash in sync with the clicking.
Yeah that wouldn' make sense either, but guess I'll try any and every idea until I bring it to Autozone.
Old Jun 24, 2012 | 01:37 PM
Well attempted the security relearn however, the lock light is supposed to stay on and it didn't. It says "service ecs, service brake sys, ecs off, service traction and all tire pressures showing --" so.. Well that def did'nt work.
Old Jun 24, 2012 | 01:53 PM
07cobaltguy's Avatar
something is blown somewere.
Old Jun 24, 2012 | 02:14 PM
You're thinking a fuse is blown, or some wiring?
Waitin for ride to Autozone, read a few similar cases of people ending up being their battery, others just had a ton of parts replaced. >
Old Jun 24, 2012 | 04:39 PM
Took the car to autozone and.. Bad battery. Checked the alternator also, was good. So $130 later, new battery and it starts meow.
Thanks to all for input and help!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
