South Mountain UT, AZ, NM, and CO
Electrical help
Old Sep 20, 2011 | 11:53 PM
Studmuffin02's Avatar
Electrical help
So today on my way home from class my headlights(hid retro fits), dash lights, and tail lights were not turning on. My fogs and everything else worked though. I've checked all the fuses and took off the negative cable to the battery. Any other suggestions, im also looking for a wiring diagram for this. Thanks!
Old Sep 21, 2011 | 01:42 AM
No ideas here?
Old Dec 28, 2011 | 05:31 AM
avenger09123's Avatar
If you checked all the fuses and whatnot associated with the lights, then the only other link in the chain between the buttons and the lights is the relays that control them. Did you check those out?
Old Dec 28, 2011 | 10:22 PM
calicobaltSS's Avatar
Dimmer switch also....only thing I can suggest is if you have the stock lights....hook them up and see if it does that same thing
Solaris99
28
Mar 15, 2017 01:22 PM
ernnyyes
Oct 2, 2015 05:16 PM
09RallyTC
Aug 27, 2015 07:05 PM
juandirtymessican
Oct 27, 2012 10:41 PM
