For Sale HD Projector
Old Jan 26, 2010 | 10:44 PM
Brenticus's Avatar
HD Projector
$300.00 plus shipping for a Notevision DLP HD Projector. This is a home theater projector that a friend wants me to sell. The bulb is brand new with no hours on it and the projector is in perfect operating order with all the wiring, remote and mounting hardware. To be honest, I would buy this myself, but I don't have anywhere suitable to put it. I'll post pics later if anyone is interested.
Old Jan 27, 2010 | 12:11 PM
M00senSS's Avatar
resolution? connects (component, hdmi, vga, etc.), model, make, etc. I have been looking at projectors lately and may want to buy.
Old Jan 27, 2010 | 09:15 PM
Brenticus's Avatar
These are the specs that I found for it:
Manufacturer: Sharp. Part Number:XR-10X
General
Device Type DLP projector .Built-in Devices Speaker .Width 12.4 in .Depth 11.6 in .Height 4.7 in .Weight 8.6 lbs .Projector / Panel
Image Brightness 2000 ANSI lumens .Image Contrast Ratio 2000:1 .Image Size 3.3 ft - 25 ft .Projection Distance 4.6 ft - 40 ft .Resolution 1024 x 768 (native) / 1400 x 1050 (resized) .Native Aspect Ratio 4:3 .Video Bandwidth 108 MHz .Max Sync Rate (V x H) 85 Hz x 70 KHz .Lamp Type 275 Watt .Lamp Life Cycle 2000 hour(s) .Projector Lens System
Zoom Factor 1.15x .Video Input
Analog video format PAL-M , PAL-N , SECAM , PAL 60 , NTSC 3.58 , NTSC 4.43 .Analog video signal RGB , S-Video , Component video , Composite video .Digital Television Video Formats 480i , 480p , 540p , 576i , 576p , 720p , 1035i , 1080i .Digital video input format DTV , HDTV .Video Input Device
Type None .Audio Input
Type None .Audio Output
Type Speaker(s) - Integrated .Sound output mode Mono .Sound Output Mode:Output Power / Channel 2 Watt .Speaker(s) 1 x Mixed channel - 1.1 in .Expansion / Connectivity
Interfaces 1 x Component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x Audio line-in - Mini-phone stereo 3.5 mm .Power
Power Device Power supply - Internal .Voltage Required AC 120/230 V .Power Consumption Operational 300 Watt
Sorry, I just copied and pasted since I honestly don't know much about these things and it's not my projector. However, the guy who owns it is my co-worker and I can personally vouche for his honesty. He says it runs like new. It's got a few scratches on it, other than that, it's in perfect working order and has a full set of connections to get you started and a user's guide disk (cd-r for some reason).
Old Jan 27, 2010 | 09:20 PM
ericgt79's Avatar
where the hell were you last month when i spent 450 on the one i bought from amazon.
how did he have it setup tho i need a screen idea.
Old Jan 27, 2010 | 10:01 PM
Brenticus's Avatar
He never set it up. He bought this two years ago for $750 and got busy and never got to use it. So now he just wants it gone. If that sounds shady it's because we both work with a mentally retarded child and before I shown up, he had him 24/7 for a good while, he was living at his house and the kid is a real handful.
btw, the cables are 25 ft of AV and coaxial.
late night bump!
Old Jan 27, 2010 | 10:04 PM
CptTheAlex's Avatar
I used to own the model just before this one and its got great picture quality. Mine sat 13-14 ft back from a 100 in screen roughly. IIRC.
Old Jan 27, 2010 | 10:05 PM
EcoTecDriver's Avatar
Would you consider 300 shipped?
Old Jan 27, 2010 | 10:08 PM
Brenticus's Avatar
i'd really rather not, but shipping shouldn't be high as i can probably fit it in a flat rate box.
even if i can't, it just isn't that big...
Old Jan 27, 2010 | 10:12 PM
fakameanrepresent's Avatar
bump for a clean projector
Old Jan 27, 2010 | 10:23 PM
Brenticus's Avatar
thanks.
Old Jan 28, 2010 | 03:04 PM
Brenticus's Avatar
morning bump.
still needs sold. any takers?
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
juandirtymessican
Oct 27, 2012 10:41 PM
