Now In Stock TTR Automatic Trans Bushings
We now have in stock the Automatic transmission bushings in "red" in stock!!!
We also have the manual transmission bushings in stock in "red"
Black and Blue are due in stock very soon!
These are only $44.99 for the SET OF TWO
Order now as they dont stay in stock long.
Here is a direct link to the product:
http://turbotechracing.com/productca...idproduct=5068
These are the genuie "Turbo Tech Racing" bushings, which has "Turbo Tech Racing" right in the mold so each bushing has it imprinted logo.
Please post when you place your order!
We have 4 sets left in stock of each
They are going fast!
Last edited by TurboTechRacing; Nov 14, 2007 at 09:56 AM. Reason: Automerged Doublepost
They come with easy to follow instructions (full color) there are a lot of install "how to's" on this forum, a simple search will bring up many of them.
Basically you take off the bracket, push out the old/soft OEM rubber bushing and push in with a vise or even your hands the new Turbo Tech Racing bushings, and re install the bracket.
You should be able to do both of them in 30-60 minutes.
bump to subscribe.
as far as needing four.
the passenger side can be beefed up, and ttr also has a mount for that. I beefed up mine with liquid poly... but it adds an amount of vibration. the lower two only really will be felt under acceleration or engine braking.
the driver side one is actually designed to break away if there is severe front impact, so I don't think I would fill it unless the car was being used as a legitimate race car.
