2010 front brembo caliper disassembly
Old Aug 22, 2011 | 12:24 AM
FantasyMike's Avatar
Thumbs up 2010 front brembo caliper disassembly
whats with the pins on the front calipers of the 2010 ss, how do i get the pins out pounding them out i heard was a bad idea is there some sort of a release? somebody have good advice thanks.
Old Aug 22, 2011 | 10:12 PM
Powell Race Parts's Avatar
the inside of the caliper ( inner fender side) the pin has a spring clip. It gets corroded from road salt and lack of maintenence.
you drive the pointed pin from outside ( road side of car) to the inside with a small hard punch that does not exceed the diameter of the pin or you will damage the caliper.
use a hi quality penetrating oil on the inside of the pin. let sit for a bit. a little heat from a propane torch on the inside of the pin
hammer from the outside.
Old Aug 22, 2011 | 11:09 PM
so just lube it up possibly torch it up and pop it out or do i have to do something with that spring clip
Old Aug 22, 2011 | 11:21 PM
the penetrating oil will attack the corrosion under the pin spring clip. the heat will help burn it up (not too hot, thats why you use a small propane torch not a welding torch,
then wire brush the heck out of the pin end , clean it up, even boil the end of the pin in water and baking soda to get rid of the corrosion. Clean up the pin bore in the caliper with a pipe cleaner and some water and CLR. Nothing too crazy aggressive you dont want to hurt the caliper. Aand install with never seize. Better is to buy a new pin kit from CED they are on the web site and not a lot of money. CED also sell calipers lol
Old Aug 22, 2011 | 11:30 PM
quick question say i do damage the pin would i be able to get a new pin set overnight from CED
Old Aug 22, 2011 | 11:33 PM
I am sure Tom has a kazzilion parts in inventory and pin kits are one of the kazillion
Old Aug 22, 2011 | 11:35 PM
appreciate your help ill let ya know what happens thanks again
Old Aug 22, 2011 | 11:41 PM
one more question on his site they only have pin kits for 08 09 cobalt are they the same brembo's on my 2010 ss
Old Aug 22, 2011 | 11:58 PM
09sscalicobalt's Avatar
08-10 brembos are all the same
Jan 12, 2016 12:01 AM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
