5x110 to 4x100
Old Jun 30, 2012 | 12:58 AM
Dark Cobaltz's Avatar
Talking 5x110 to 4x100
Alright guys, I have a 2009 2.2L Cobalt with the 4x100 bolt pattern.
and my buddy has the 5X110 bolt pattern, he totaled his cobalt a while back and he had JUST bought a $1000 set of rims for his old cobalt that was 4x100, he and him got talking and he wants 4x100 again and I want 5x110 for the SS/NA rims and we wanted to know if we can swap bolt patterns.
I have stated everything about why we want to do this UP above.
Is it possible without buying anything extra?
and we both have rear drums.
PLEASE NO TROLLS OR STUPID COMMENTS, pretty please.
Thanks for looking.
PS I know 4x100 has more rim options, I don't really care.
I like the look of the SS/NA rims.
Old Jun 30, 2012 | 01:06 AM
Omnigear's Avatar
4x100 have more rim options...
i think you can just swap hubs.
not sure about abs n ****
Old Jun 30, 2012 | 01:10 AM
I know 4x100 has more options,
but i'd like to help a buddy out and I like the look of the SS/NA rims.
btw, thanks for the post.
LS6Rally's Avatar
Both of you have the same trans? If not check to see the hubs for a stick and auto are the same pn. And then you need to be aureboth car have the same amount of splines.
Are the drums the same size?
Both have or dont have abs?
Old Jun 30, 2012 | 01:15 AM
Yes we both have ABS.
And we a both auto, He has a 2006 cobalt SS/NA
and I have a 2009 2.2L LT.
and what exactly do you mean by splines?
Brake lines?
Old Jun 30, 2012 | 07:50 AM
BLKLS's Avatar
All you need to do is swap hubs and brakes. I just went from 4x100 to the 5x110. No problems at all, only thing is I don't have abs. Pretty sure the tooth count is different on the two hubs so neither one of you will have working abs after. But everything swaps easy.
Old Jun 30, 2012 | 08:02 AM
You have a how to you used?
Would be greatly appreciated.
Old Jun 30, 2012 | 08:19 AM
BLKLS's Avatar
No, I was gonna make one but I got a little pressed for time so I didn't take enough pictures. Pretty straight forward tho. Get the wheels off, take off the rear drums, the hubs have four bolts I believe they were a 15mm, in bolt rear hubs. You don't even have to take the shoes off but recommend you change them I got a vibration from not doing this. Bolt them backup rear is done. For the front, get the calipers and bracket off, undo the axle nut, get the rotors off and the hubs have three bolts remove hub reinstall in reverse order. Disconnect the front brake lines from the calipers replace the crush washers tighten the banjo bolt, install calipers and brackets bleed the brakes.
https://www.cobaltss.net/forums/susp...g-swap-280250/
There's a link to my photobucket with the pics I took.
Old Jun 30, 2012 | 08:22 AM
Pretty straight forward not hard at all.
Thanks man.
Is there a karma function or something, cuz I wanna give you one big for all the nice info.
I'll make sure to take pictures.
Old Jun 30, 2012 | 11:10 AM
2000Firehawk's Avatar
Noooo....
I'm doing a 5x110 to 4x100 swap on my HHR SS.
The 'teeth' count is different between the two hubs...
You will lose your ABS.
But, maybe because this is a Cobalt to Cobalt swap, something can be done
To keep the ABS ???
ItalianJoe1 is converting my 5 lug hubs to 4x100 , so that I
Can keep my ABS...:
Old Jun 30, 2012 | 11:23 AM
Originally Posted by 2000Firehawk
Noooo....
To keep the ABS ???
Can keep my ABS...:
Sounds fun Haha, ill have to look into it more about the abs, ill throw a code if I don't have my abs hooked up wouldn't I?
So for sure the teeth are different on my cobalt then his or no?
Old Jul 6, 2012 | 10:01 AM
zerosk8ter83's Avatar
I dont see why our abs wouldnt work if we both have it
Old Jul 6, 2012 | 12:33 PM
Yeah, I don't think there would be a problem.
Anyone else wanna got anything to say about this?
Anyone see any problems with brake likes or anything?
Old Jul 6, 2012 | 03:54 PM
Do an 'ohm' check, on the different hubs.
With my 5 lug ABS hubs, I get 1.5K ohms.
With the Cobalt 4 lug ABS hubs I have on the rear now, 'open' circuit, infinite ohms.
So I have ABS light, traction control light, & ESC light on.
My dash looks like a lit-up christmas tree, at night....
Old Jul 6, 2012 | 04:36 PM
Ill just put some resistors if necessary
Old Jul 6, 2012 | 04:47 PM
It's not about the resistance of the circuit...
It's the type of sensor being different...
The ECM /BCM is expecting a certain signal.
Also the 'teeth' count is probaby different too...
Old Jul 6, 2012 | 04:49 PM
I dont think so,same transmission so hopefully the teeth are the same. Wont know till we try tho
Old Jul 6, 2012 | 04:59 PM
ChevyBoi89's Avatar
What SS/NA's come stock with drums??? ....my 2006 SS/NA has discs all around!
Old Jul 6, 2012 | 05:01 PM
mine had drums for some reason, first think I noticed when I went to go look at the car. It was prom in a accident or something
Old Jul 6, 2012 | 05:13 PM
LS6Rally's Avatar
Had to have been swapped to have drums.
On the tooth issue, both cars may have the same trans, but diff ratios and tire size will make a difference
Old Jul 6, 2012 | 05:24 PM
stenguyen1's Avatar
i'm selling my rims that are 4 x 100 if you interested. with tires.
Old Jul 6, 2012 | 05:58 PM
I already have rims that were on my old cobalt (2.2) brand fkin new two where only on the car for a month when it got totaled. So i want to do this swap to put them on the 2.4. There 17's and the tires size is 215 17 45 (i think)
Old Jul 6, 2012 | 06:26 PM
according to this it will fit
https://www.cobaltss.net/forums/2-2l...ability-58013/
Old Jul 6, 2012 | 06:46 PM
kingg5's Avatar
are you guys not comprehending what is being said to you?
it has nothign to with fitting...ITS A GODDAMN SENSOR that is different. how can you have abs if the sensor is different.
Old Jul 6, 2012 | 06:47 PM
eh Ill make it work somehow
