ABS help.
Old Mar 20, 2009 | 08:38 PM
Spectral's Avatar
ABS help.
Ok so im getting rid of the redline and i swapped my struts and rotors and pads with a buddy up here and now I have an ABS light.
What could we have done that fucked up my ABS
The 2 front sensors look to be intact and plugged in fine.
Is there anything with the rear rotors that could have been fucked up?
Old Mar 20, 2009 | 08:40 PM
Black SS/SC 06's Avatar
That's weird, didn't happen to me when I did mine.
Old Mar 20, 2009 | 08:42 PM
Spectral's Avatar
didn't happen to me when i did my springs and rotors the first time either.
im at a loss right now lol.
Did you disconnect any of the brake lines?
Old Mar 20, 2009 | 08:44 PM
Bika's Avatar
Fail Less.
look at the rear wheel speed sensors.
Old Mar 20, 2009 | 08:45 PM
Spectral's Avatar
Not to my knowledge. Only thing that we "disconnected" was the sensor in the front which both are intact and fine.
What is also confusing me is that last night the whole way home which was about and hour drive the ABS light never came on.
What do those look like or what are they by?
Old Mar 20, 2009 | 08:46 PM
Yea could be dirty sensors. You could try disconnecting the battery to see if it goes away lol.
I am not even sure where the damn sensors are off the top of my head lol.
Last edited by Black SS/SC 06; Mar 20, 2009 at 08:46 PM. Reason: Automerged Doublepost
Old Mar 20, 2009 | 08:49 PM
Spectral's Avatar
They are held on by the bracket that comes off when you take out the bolts to remove the strut and crap.
Old Mar 20, 2009 | 08:51 PM
oh ok. well i would check the sensors first and if cleaning them doesn't help disconnect the negative on the battery for a few minutes and see if it goes away
Old Mar 20, 2009 | 08:58 PM
Bika's Avatar
Fail Less.
the rear ones should be on the back of the hub... similar set up to the front. sensor over the teeth on axle type deal
Old Mar 20, 2009 | 08:59 PM
Spectral's Avatar
ill give those a look in a little while.
Old Mar 21, 2009 | 06:19 PM
SoloZ/SS's Avatar
you can't clean the sensors. Did you have the ignition on when you swaped the suspension and disconnected the sensor harness? if that is the case the computer has allready seen the sensors are ok and the light wont come back on.
Old Mar 21, 2009 | 10:46 PM
Maven's Avatar
If it took an hour for the light to come on its likely a coincedence or youve got a harness pinched. Wheel speed codes are usually instant faults.
turbochargedss2012
Sep 20, 2023 12:17 PM
Meadowvalien
Aug 17, 2017 06:32 PM
Sep 30, 2015 07:22 AM
jthwjde
Sep 7, 2015 09:24 AM
