ABS Light Help
Old Jun 19, 2009 | 08:46 AM
victoryss's Avatar
ABS Light Help
Recently I was doing some suspension work on the front drivers side of the car. I had to apply some lubricant(wd40) to loosen a nut and the lubricant(wd40) got inside of a abs sensor that sits right next to the hub assembly. Now I have the ABS light on and I thoroughly cleaned the sensor off but to no avail the light is still on.... Any suggestions/reccomendations? OR do I need to get a new sensor?
Old Jun 19, 2009 | 09:03 AM
steddy2112's Avatar
Probably need a new sensor...chalk that up to learners cost.
Old Jun 19, 2009 | 09:07 AM
steddy2112's Avatar
:grrr
Old Jun 19, 2009 | 09:08 AM
steddy2112's Avatar
Probably need a new sensor, I would chalk it up as a learners cost.
Old Jun 19, 2009 | 10:49 AM
victoryss's Avatar
Need to find sensor:suicide:
Old Jun 19, 2009 | 10:51 AM
steddy2112's Avatar
Probably need to update the ******* server.
Piece of ******* ****.
Old Jun 19, 2009 | 10:59 AM
victoryss's Avatar
x2.... on that. jesus christ.
Old Jun 20, 2009 | 12:53 PM
Maven's Avatar
Sensor is part of the wheel bearing/hub assembly.
I would make sure have a good clean electrical connection, before you replace a hub, and maybe actually find out if thats what the light is on for.......just a thought.
This is one more reason why WD40 should only be used for removing sticker redsidue.
Old Jun 20, 2009 | 02:31 PM
Stittville Ed's Avatar
I don't even use it for that anymore
My son raced karts and they would send us a case every year and the very best thing were the stickers shaped like a WD-40 can.
Very cool and fit right at the bottom of the stearing wheel faring.
Old Jun 20, 2009 | 02:33 PM
usmc6212's Avatar
ive had that problem with mine havent been able to find parts. besides at the stealership. if i remeber right its the wheel speed sensor.
Old Jun 20, 2009 | 09:14 PM
Maven's Avatar
The wheel speed sensor is integral to the hub/wheel bearing unit.
They are available online at at decent parts stores
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
