alignment corrections
Old Apr 25, 2007 | 09:53 PM
yellow_cobalt's Avatar
anybody have access to an alignment correction calculation? i want to calculate the new alignment after using the progress springs. i want to know the numbers in hand before taking it to someone and telling them where to set it. otherwise, they would just set it to stock.
i would just try and set it myself good ole' make shift way, but i have absolutely no flat ground here to do so.
Old Apr 26, 2007 | 09:21 PM
blktrax's Avatar
There aren't alignment corrections, stock is where you want it.
Camber = The angle that the tire sits perpendidular to the road.
Caster = It is the angle between the pivot line that runs through the center of the upper ball joint to the center of the lower ball joint.
Toe = If the tires are point toward each other or away from each other.
The closer to stock these settings are the longer your tires will last.
If youre autocrossing you can have them use more Negitive Camber, helps with cornering but wears the inside of the tire faster.
0 degree toe or slight toe out helps even more with tight corners, but can make the car feel nervous and twichy at hiway speeds.
Old Apr 26, 2007 | 10:25 PM
RA071623's Avatar
All the Cobalt's have the same adjustment its just the Front Tire Bar adjustment or "TOe" as stated by Blktrax.
Old Apr 29, 2007 | 11:52 PM
denn454's Avatar
without the alignment kit there is no way to change the alignment. they can slot the holes on the tops of the struts for camber (or is that caster...) but thats about it.
I don't know why everyone thinks they need an alignment after changing the springs, you don't. its idiot proof. I got a free alignment check and its right where it should be, since i couldn't have messed anything up if i wanted to.
I can only speak for the 2.2's. maybe the ss's have some adjustment but i would be shocked to find out they do.
Old Apr 30, 2007 | 09:53 AM
RA071623's Avatar
Nope Denn your right my allignment was perfect, when they threw it on the rack to check it. I noticed when I was driving my car hard to let the springs settle that it really wasn't a big deal.
TotalChaos
Oct 14, 2015 06:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
Jeffwills14
Sep 6, 2015 06:52 PM
