Alignment Problem
Alignment Problem
Just had my '06 SS/SC lowered last week w/Eibach Sport lines. AT the time the shop
could not get the rear wheels into speck, front are fine. They said bring it in after a few days ket the springs "settle in" and then they'll check it again. They did so and it's still
and the right rear is toed in. They say there is no adjustment. Has anyone had this problem and if so were you able to correct it? Thanks
there is a way to adjust the rear it uses shims behind the hub that is the adjustment or if it is so small of it being in green then you could just maybe shift the beam back there do you have the print out sheet
was the 518 just for the spings installed and alignment
The 518 was for the springs installed and all the alignment checks before the intsall,
after and the re-check.
The quote says 54.75
Last edited by fjordbosun; Apr 29, 2009 at 02:49 PM. Reason: Automerged Doublepost
that's pretty good. Thanks. I know it's not going to be exact for my car, but gives me a general idea.
around 460 for the install of 4 springs that is kinda bad my shop i work at only charges around 280 to 320 for springs and struts
can you get the whole print out to me in like a pm or something i want to see what specs they used because i did whitessbalt's and the rear was fine i am doing tintredss on friday putting springs in and aligning it for around 30 to 50 dollars sorry you live so far away
DANRICKARD
Oct 1, 2015 12:08 AM
