Alignment Problem
Old Apr 29, 2009 | 01:53 PM
fjordbosun's Avatar
Alignment Problem
Just had my '06 SS/SC lowered last week w/Eibach Sport lines. AT the time the shop
could not get the rear wheels into speck, front are fine. They said bring it in after a few days ket the springs "settle in" and then they'll check it again. They did so and it's still
and the right rear is toed in. They say there is no adjustment. Has anyone had this problem and if so were you able to correct it? Thanks
Old Apr 29, 2009 | 02:21 PM
wardzach2007's Avatar
how much did it cost for your alignment?
Old Apr 29, 2009 | 02:24 PM
fjordbosun's Avatar
518.00 For the springs install and alignment. no charge for the second alignment check
Old Apr 29, 2009 | 02:26 PM
yel-low's Avatar
there is a way to adjust the rear it uses shims behind the hub that is the adjustment or if it is so small of it being in green then you could just maybe shift the beam back there do you have the print out sheet
was the 518 just for the spings installed and alignment
Old Apr 29, 2009 | 02:34 PM
exiged's Avatar
there isn't anything to adjust on the rear. . . . . . . . . ?
Old Apr 29, 2009 | 02:39 PM
yel-low's Avatar
yeah there is if you use shims i have done it on caravans cavys and cobalts use just have to get an aftermarket shim kit
Old Apr 29, 2009 | 02:43 PM
do you know how much it would be w/o the spring installment?
Old Apr 29, 2009 | 02:49 PM
fjordbosun's Avatar
Thanks for the input, I'll look into that the sheet says -.03 in the red
The 518 was for the springs installed and all the alignment checks before the intsall,
after and the re-check.
The quote says 54.75
Last edited by fjordbosun; Apr 29, 2009 at 02:49 PM. Reason: Automerged Doublepost
Old Apr 29, 2009 | 02:51 PM
that's pretty good. Thanks. I know it's not going to be exact for my car, but gives me a general idea.
Old Apr 29, 2009 | 03:11 PM
yel-low's Avatar
around 460 for the install of 4 springs that is kinda bad my shop i work at only charges around 280 to 320 for springs and struts
can you get the whole print out to me in like a pm or something i want to see what specs they used because i did whitessbalt's and the rear was fine i am doing tintredss on friday putting springs in and aligning it for around 30 to 50 dollars sorry you live so far away
turbochargedss2012
Sep 20, 2023 12:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
