Alignment on sportlines?
Old Mar 21, 2012 | 04:07 PM
blackjack232's Avatar
is it hard to do an alignment with sportlines on stock struts?
Old Mar 21, 2012 | 04:21 PM
ItalianJoe1's Avatar
Only if you think it's hard to align stock.
There is only ONE thing to adjust on these cars from the factory, that's the front toe setting. Which doesn't change when you lower the car. Alignment is not needed.
If you want to change camber, you have to start using aftermarket parts because there is no built in adjustment stock.
The rears are fixed due to the axle design, so it's not hard to adjust something that doesn't get adjusted.
Old Mar 21, 2012 | 04:28 PM
so, if I had been lowered on sports, is only really need camber adjustment?
possible solution using camber bolt kits? (progress alignment kit from andy's?)
Old Mar 21, 2012 | 04:54 PM
Doesn't need anything, and the camber can't be adjusted so I don't worry about them. I've put in many sets of springs and not aligned after, it doesn't change any of the settings. If you needed an alignment after springs, you needed one before and just didn't know it.
Old Mar 21, 2012 | 05:10 PM
hmm, so you've never experience odd tire wear on the inside?
Old Mar 21, 2012 | 05:15 PM
07LSJ's Avatar
uhhh dont tell me you got the same problem as me...
Old Mar 21, 2012 | 05:26 PM
Nope. I ran sportlines for over 40K miles and several different sets of tires with no issues, even wear all across. They don't add enough camber to change anything.
Old Mar 21, 2012 | 05:38 PM
hmm perfect thanks a bundle
Old Mar 21, 2012 | 09:47 PM
VapeWI's Avatar
What!!! I ******* got had for $80 . I was told it is required to get an alignment after a lowering spring install.
Old Mar 21, 2012 | 09:59 PM
Sorry to tell you, most alignments done in shops are smoked, there isn't a reason to adjust unless they are way out and wearing tires or something. They'll show you the .03 degress they adjusted, but you won't notice it. If you come in asking for an alignment but there isn't anything wrong, tires wearing well, all that, what would they want to change that for? They will go through the motions as alignments are all labor and the techs usually get paid very well for them, but often times little if anything is changed.
Old Mar 21, 2012 | 10:48 PM
Frogstofall's Avatar
I feel like you just released the biggest secret in automobile history.
I wonder if anyone will challenge your statement.
Old Mar 21, 2012 | 10:51 PM
now the battle begins, Sportlines versus the CM Cobalt SS springs? which is a goodie?
Old Mar 22, 2012 | 01:13 AM
Just being honest.
IF they challenge it, they are lying. I know there are some people who do jobs correctly, but the majority doesn't.
Old Mar 22, 2012 | 09:45 AM
DirtyBalt09's Avatar
Hes not lying. I've done so many were you set up the car swing it and it's all green.... Cool two hours of pay. It's like that but since techs lose their ass alot on other jobs the just book it and see you on your way.
Old Mar 22, 2012 | 10:32 PM
iToastie's Avatar
So... my wheel isn't 100% straight, I'd say of a precentage, it's about 95% straight.
I'm buying lowering springs, I assumed I needed an alignment done, now you're all saying I don't?
If so, that saves me $80
Old Mar 23, 2012 | 01:03 AM
If your wheel is off center you will need an alignment to fix that, you probably slightly bent something at one point. Still has nothing to do with lowering the car.
Old Mar 25, 2012 | 07:56 PM
07cobaltLScoupe's Avatar
just throwing this out there but when i put my eibach pro-kit on with stock struts and shocks my front camber was off about 3 degrees, enough that you could see it. if i recall correctly spec is around 1.2 degrees max. we got it back within spec by drilling the 2 hub bolt holes out a little larger where the strut bolts to the hub... if you don't have the right camber set-up your car WILL NOT handle as well as it should
Old Mar 25, 2012 | 08:17 PM
dakotaspeir's Avatar
#cobalthoes
I remember I lowered my 1st cobalt on sportlines and never had it alligned and it took about 2 years (switching off and on for winter) and the inside of the tire finally rounded off lol
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
Haily229
Sep 17, 2015 07:18 AM
CobaltSS 16
Sep 12, 2015 02:43 PM
