any one have problems with EBC
Old Jul 19, 2008 | 08:38 PM
auggie_ss_phx's Avatar
well does any one have the same problem as me? i order the EBC dimple sloted rotors and green stufff pad from ttr(wich they are great people). i had them on for 3 to 5 k miles(around the middle of may i installed them).but i have this noice coming from my rotors/pads. sounds like i have no pads left. it squeaks(sounds like crickets) alot when i am just driving at any speeds and it kinda quiets down when i apply the brakes it gets louder and then it quiets down. any one??what u guys think it could be? bad pads or rotors?
Old Jul 21, 2008 | 02:56 PM
cgss's Avatar
my ebc's you can hear as you drive its quiet but its there. it goes away when braking however. i've heard that that is normal and what performance brakes sound like
Old Jul 21, 2008 | 08:11 PM
VRCobalt's Avatar
I have ebc pads and I dont hear a thing.
Old Jul 21, 2008 | 08:12 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
You need to take the brake pads off and apply antiseize on the back of them (opposite the side that touches the rotor, obviously)
Old Jul 21, 2008 | 08:26 PM
MidnightNB's Avatar
I just got the rotors but dont have them on yet and didnt get new pads. I only have 26k on my stock pads, is it ok to run it with those till I buy hawk pads in month, or should I just rush-order the pads and wait to put the rotors on?
Old Jul 21, 2008 | 08:27 PM
lewisb13's Avatar
I wouldnt put used pads on new rotor surface.
Old Jul 21, 2008 | 08:28 PM
BlueSS-supercharged's Avatar
might as well get the pads too, no sense wasting time
Old Jul 21, 2008 | 08:30 PM
quicksilver41's Avatar
I can hear mine as well. I have EBC drilled and slotted rotors and EBC red stuff brake pads. They are the ****.
Old Jul 21, 2008 | 10:44 PM
i have done it twice alredy and it still there
x2 i hate them i am really upset with this set up EBC
Old Jul 22, 2008 | 10:02 AM
Hotwired2689's Avatar
awesome i just just bought and installed this setup EBC slot and drilled/green stuff.......im prolly just about tru the break-in stage i was hoping that damn sound would go away...whats the deal with it? it is quite audable even with windows up :/
Old Jul 22, 2008 | 10:10 AM
TurboTechRacing's Avatar
Did anyone have the EBC rotors and HAWK pads? If so is the noise still there? That way we can pin point if it is the rotors whistling or the pads.....
I think as EBC stated it is the Cooling properties of the rotors that cause this... I guess it is a function of having a better cooler rotor.
Old Jul 22, 2008 | 12:31 PM
i wasnt to concerned with it i just passed it off as noise from break-in but my next pads for them are gunna be the ceramics most likely...they look awesome tho
Old Jul 22, 2008 | 02:32 PM
cgss's Avatar
i have the ebc slotted and dimpled with hawk hps pads and its just a whistle that you hear on a bridge or when a car is near you. cant hear it with the windows up
Old Jul 22, 2008 | 07:56 PM
I dont see how it would be the "pads" as the pads are not touching the rotors unless you are braking....
Old Jul 22, 2008 | 10:18 PM
Switt23's Avatar
I have the ebc's and greens. It makes the normal sound from performance brakes whenthe brake is applied, but i don't get awhole lot of whistling while driving.
I know they had a big problem with improper break ins. If you hard breaked too much during the break in period they have been known to squeak a little, but I think the whistle noise would be just the areodynamics of the rotors.... the dimples.
Old Jul 22, 2008 | 10:21 PM
Very true the first 500-1000 miles you do not want to step on the brakes hard...
Old Jul 22, 2008 | 10:53 PM
i never did i just dont really get wtf could it be do
Old Jul 24, 2008 | 01:07 AM
this has something to do with my rotors, i posted a new thread, it was a lengthy explination and i didnt want to hijack
https://www.cobaltss.net/forums/problems-service-maintenance-69/little-explination-bad-day-im-having-123997/
Old Jul 25, 2008 | 09:58 AM
any one alse??
Old Jul 25, 2008 | 03:49 PM
bluebaltjim's Avatar
i have the ebc rotors and hawk hps pads and since day one i have the same cricket sounds. ive heard it's because the rotors are dimpled instead of drilled, they're stronger than drilled but the sounds waves are reflected out of the dimple. i've had mine for over a year and im pretty used to them now, the sound is still there but it doesn't really bother me. sometimes someone will suggest i have nails in my tires because they hear it and i just say ohh thanx. all in all i'm happy with the performance of the setup, it's served me well on autox days, but id like a nice quiet setup next.
Old Aug 27, 2008 | 09:58 AM
Mimmsey's Avatar
I have the same setup on my car, and i get the cricket sound, I thought i needed to break the pads and rotors in but ive had them on my car for about 3k miles now and nothing has really changed, its annoying when you have the windows down but its livable.
Old Aug 27, 2008 | 10:06 AM
D4u2s0t's Avatar
absolutely not. your pads "match" your rotors. so the stock pads are matched to the stock rotors. you will very possibly damage your brand new rotors by using the old pads. especially if the old rotors were grooved or warped.
why are you upset? because they make noise? you should have researched before you bought, and you would have found out that they're going to make more noise than stock. this is almost as rediculous as saying "I'm pissed, my magnaflow exhaust made my car louder than stock".
i have the ebc and hawk hps pads, and LOVE it! yea, it's a little noiseier than stock, but it says right on ebc's website that it will be louder, just like you said Aaron because of the cooling properties. Air is rushing through those slots and dimples as you drive.
Old Aug 27, 2008 | 10:25 AM
07hhr's Avatar
I also have EBC red stuff pads and dimpled and slotted rotors and i to get the noise, i did contact EBC numerous times and they say its normal with these, I'm used to it now though. i thought front brakes did drag a little bit since there is no springs or anything to pull the pads back from the rotor.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
