B&G coilover help...
Old May 23, 2009 | 01:22 PM
4doorcobaltowner's Avatar
Hey...i recently purchased used coilovers off a member on here. I'm having a little trouble figuring out how to install these. Anyone who has them willing to Email me or have AIM to answer a few questions for me. Thanks tom
Old May 23, 2009 | 06:57 PM
tru2nrtt777's Avatar
Um... what is the problem? Remove old, Insert new... Unless he didnt give you all the parts...
I dont have them but I have installed several sets of c/o on Cobalts.
Old May 24, 2009 | 12:25 AM
well wish it was that simple....i have done alot of suspensions before and the only thing is on the coilovers, B&G says something about adjusting the shock height to the size of the drop which i dont really know how much...and the front sway bar links, where i set those to? And i am missing the coilover keys and rubber insulator for the top of the rear spring.
Old May 24, 2009 | 12:48 AM
Well that is not good. You should have holes mounted to the strut housing that the endlink bolts go through. Coilover adjustment keys should be pretty easy to obtain, any tuner shop should have them and you can get them off the interweb. Rubber insulators? why can you use the stock ones? That is what I had to do when I installed KW's on my friends LS.
Old May 24, 2009 | 01:00 AM
the strut mounts are on the front coilovers, but they can go up and down, and i don't know where i should set them to?
Old May 24, 2009 | 06:53 PM
You mean sway bar mounts? I believe since it looks like youre a LS you would need to adjust them upward since the FE1 suspension has longer endlinks
Old May 25, 2009 | 02:05 AM
niknyce's Avatar
SS* ..... fe5
Old May 25, 2009 | 02:27 AM
atownSS's Avatar
On the B&G coilovers you adjust the front ride height with the strut mounts. That is why they move. You only want to adjust the spring seat to where the spring has a small amount of tension on it so when you hit a large bump the spring doesn't move off the seats. Also on the rear the stocks are length adjustable so when you lower the car the shocks aren't already compressed how ever many inches you lowered the car.
Old May 25, 2009 | 07:12 PM
Originally Posted by niknyce
SS* ..... fe5
If he is not turbo it would be FE3 and I didnt notice the SS on the bumper. I am not sure where he would need to adjust them then because I dont know how long the FE3 endlinks are.
Old May 26, 2009 | 03:05 AM
niknyce's Avatar
i meant le5 lol
Old May 26, 2009 | 04:19 PM
Bumpin Balt's Avatar
Email B&G. They will email you the instructions.
Old May 26, 2009 | 11:03 PM
i meant le5 lol
Sure ya did.
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
PotatoLvrd
Sep 2, 2015 01:25 AM
