BC racing too high in back
Old Mar 19, 2011 | 07:39 PM
Cobaltpunk's Avatar
Ive got the BC racing coilover kit. I like it a lot, except the springs in the back are a little too tall even when the adjustment is as low as possible. I emailed B&G suspension about possibly buying just back springs. Theirs look the lowest. So it they are too low I will hopefully be able to just put the adjustment from my coilovers in their springs and do how I please. Right now my fenders are sitting about 25" from the ground. The picture is a little lower because of the incline. Anyways. I wouldnt mind eating up another half inch, or a little more.
So please, voice your opinion or concerns.
Old Mar 19, 2011 | 07:42 PM
Ting-ting's Avatar
stance sells just springs
and stance is the lowest
Old Mar 19, 2011 | 07:46 PM
Cobaltpunk's Avatar
Do they sell just rears?
Old Mar 19, 2011 | 07:47 PM
Ting-ting's Avatar
yeah you have to call them they can make custom springs for dif rates
its like 50 a spring i think to
Old Mar 19, 2011 | 07:57 PM
Cobaltpunk's Avatar
Thats not bad.
Old Mar 19, 2011 | 08:04 PM
Ting-ting's Avatar
Yeah not bad at all
Old Mar 19, 2011 | 08:06 PM
Cobaltpunk's Avatar
Do you know what Kind of spring rates I would want to go with. I dont mind a stiff ride, will I need to take my rear springs off again to tell them how long they are, or is that have to do with the rates. Please educate me.
Old Mar 19, 2011 | 08:13 PM
Omnigear's Avatar
10k
Ting-ting's Avatar
Not sure it depends how you use them
Old Mar 19, 2011 | 08:15 PM
Cobaltpunk's Avatar
Omni, all the springs on Stance's website say 2 numbers. The first is 4k-12k. the second is a number between 150 and 250. What are each of those?
Old Mar 19, 2011 | 08:45 PM
BlilBT's Avatar
Take out the Gold adjustment rings on the back, will give you another 1/2 easy!
Old Mar 19, 2011 | 08:49 PM
Cobaltpunk's Avatar
BlilBT. I did that today, the picture is after I think Ill need new springs.
Old Mar 19, 2011 | 08:51 PM
BlilBT's Avatar
HUH, mine is a little lower than that, but yea if you did that already then springs it is!
Old Mar 19, 2011 | 08:57 PM
Cobaltpunk's Avatar
Ive got 225/45/18 tires. How bout you? Ive had the springs since about august 10' I just want to see what all is different
Old Mar 19, 2011 | 09:09 PM
poundz9oh9's Avatar
Check out the pics in my garage, that's on BC's
Old Mar 19, 2011 | 09:10 PM
Omnigear's Avatar
Metric other is sae
Old Mar 19, 2011 | 09:15 PM
b00sted06ss's Avatar
you mean just coilovers?
Old Mar 19, 2011 | 09:28 PM
Cobaltpunk's Avatar
The back part of the coilover suspension is basically the same as regular springs. It has an adjustable strut and a metal cylinder with rings that goes on the spring that can adjust the height.
Old Mar 20, 2011 | 09:29 PM
zks's Avatar
zks
I think your shocks can't go that low to hold the springs snug in place and maybe give them a bit of preload. Check that out, but if I'm right, and you don't mind rolling on loose springs and messing up your ride, then go for it.
Old Mar 20, 2011 | 09:40 PM
07blackg5's Avatar
Slobodan Milošević
^^^^yep, its that the shock doesnt adjust short enough
it drives me crazy with mine... i would go an inch lower if i could
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Cptnslo
Sep 24, 2015 09:32 AM
The Rookie24
Sep 20, 2015 04:33 PM
ashalle2
Sep 16, 2015 10:36 PM
