Bleeding ABS brakes
Old Nov 13, 2012 | 12:24 PM
Rubbermaid_LSJ's Avatar
Bleeding ABS brakes
Is anything needed to completely bleed the system? On my previously ABS equipped vehicle, my ABS pump was a closed loop that was only open when ABS was engaged. This caused a problem when trying to completely bleed the system. I would like to remove all the old fluid and replace with DOT4. I know that they are compatible, I just want all the old fluid gone and am wondering if I need the module to open the ABS system, or if I can do a full system cleanse in my garage.
Thanks!
Old Nov 16, 2012 | 02:02 PM
Anyone?
Does everyone just bleed all the fluid out of the lines, and say good enough?
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
