Brakes SUCK!
Old Dec 12, 2013 | 08:45 PM
seeyaass's Avatar
I've bled the brakes 3 times, and got them vacuum bled today and confirmed no air in the lines. Pedal still feels like crap...
Being that my esc doesent work, in order for me to drive I have to turn it off if I don't soon as I get over 10mph abs kicks on and says "ESC ACTIVE" I have to go to the dealer to get this fixed. I'm getting sick of throwing parts and pulling my hair out trying to get these famous brembo brakes to work better than my grandmas Oldsmobile.
Old Dec 12, 2013 | 08:46 PM
seeyaass's Avatar
Originally Posted by ECaulk
Thats assuming there is air in the abs. But the techII will also be able to tell if there is a sensor going back causing the issue
I think this is exactly what's causing this problem.
Wired's Avatar
My brakes feel inferior to my last SS (2007). I changed pads and rotors all around and they feel a bit better but still will do almost the same thing, but not as bad. They sometimes feel really firm and great and sometimes a bit more squishy, but never to where I feel unsafe. Car will stop fine, just not as fast as my last car with regular calipers.
The parking brake would also change in where it would need to be pulled to. Started at 10 clicks then went to 4 and then to 8.
Then i greased the **** out of the rear calipers and reset them, and now the pedal feels much better since and the parking brake goes to 7 clicks. Car will now stop almost as fast as my last car but it definitely takes more force on the pedal to do so.
Old Dec 12, 2013 | 08:50 PM
seeyaass's Avatar
You got a how to on how to reset the rear calipers?
Old Dec 12, 2013 | 08:52 PM
Sox-Fan's Avatar
Got Brakes?
i'm putting all of my poker chips on VSS. One is reading more than 10% different than the one opposite it and making the ESC think a tire is spinning. That it hits in right at 10 mph is yet another clue.
Get a TechII on it, get the EBCM codes read, get the VSS output read.
Old Dec 12, 2013 | 08:54 PM
Its possible. I can use them for free anyway :p
lucky
seeyaass's Avatar
Yea it's always right around 10-20 mph after I get to the top of first and shift into 2nd it comes on.
Old Dec 12, 2013 | 08:56 PM
What soxfan said makes a lot of sense if you have a bad wss.
Def a problem with the VSS
Old Dec 12, 2013 | 09:04 PM
seeyaass's Avatar
Never thought that it could mess with the feeling of the brake pedal though. I guess it's all tied in somehow huh.
Old Dec 12, 2013 | 09:06 PM
  #36
footballplaya3k's Avatar
I have the same issue. It seems vacuum related to me...
Old Dec 12, 2013 | 09:13 PM
  #37
Sox-Fan's Avatar
Got Brakes?
That thought crossed my mind, but I could find no indication of a vacuum leak anywhere.
Old Dec 12, 2013 | 09:25 PM
  #38
seeyaass's Avatar
Ya see I thought vacuum at some points too.. BeCause if I wind out second gear sometimes and let it cruis down or press the brakes while it's revved high sometimes they will feel real firm for a second. But it just don't make any sense to me at all.
Could anyone second this or maybe some explanation? Or maybe it's in my head lol.
Old Dec 12, 2013 | 09:32 PM
  #39
seeyaass's Avatar
I hope I get the pedal feeling how the brembo should feel, jus so I could help some people out lol. And get my brakes working how they should
Old Dec 13, 2013 | 05:16 PM
  #40
seeyaass's Avatar
So I recalibrate my rear brakes today.. And surprisingly it made a big improvement in my brakes. They were rock hard pulling out of my driveway on the first stop.
As I drove around they felt good but definitely not 100% still squishy but the brake actually bit! But still seemed a little squishy
Now if I did this a few more times, could this fix my pedal feel and fix my issue? ..
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
