Brembo brakes
If he already has the 5lug bolt pattern there is no need for the lsj hubs from the front end and fairly certain the back end also. No need for the LSJ front brake lines either, same setup as the base (I literally bolted the LSJ caliper in the same place, used new crush washers, new rotor and pads worked like a charm)
Well you assumed correct but I still am not to sure what you guys are referring to when you say LSJ
