clunking in front end
Old May 23, 2013 | 06:07 PM
trixx209's Avatar
Any idea what this could be , my guess would be the control arm bushing . but I figured asking wouldnt hurt .
I Only seem to notice it when I hit a bump and/or crank my steering wheel back and forth , And you can feel it under your feet . Thats the best I can explain .
Old May 23, 2013 | 06:23 PM
turbosmart4's Avatar
Mine does this too. Passenger side only tho
Old May 23, 2013 | 07:34 PM
microgab's Avatar
Same here
Old May 23, 2013 | 07:37 PM
LS6Rally's Avatar
Could be cabs, could end link, could be strut mount.
Old May 26, 2013 | 11:33 AM
ss88's Avatar
Same problem here. Control arm bushing as well.
Old May 26, 2013 | 11:56 AM
mrbelvedere's Avatar
this is the performance section not the suspension section learn how to post in the correct section
Suspension - Cobalt SS Network
Old May 26, 2013 | 05:10 PM
moved to suspension
Old May 26, 2013 | 06:07 PM
akurma's Avatar
had a clunking sound in mine too, when i turned left or right. i replaced my strut mount and its gone
Old May 28, 2013 | 08:03 AM
suprafanatic26's Avatar
check your sway bar end links.
Old May 28, 2013 | 11:26 PM
Bad-A-SS's Avatar
THIS x100
Old Jun 7, 2013 | 12:27 PM
Cman46290's Avatar
If i drive on any smooth road my car feels great... no noises... and all feels tight. If i drive on a rough/bumpy road... towards the passenger side it makes a clunking noise over almost every bump... and quite annoying... steering wheel feels/stays tight... but the noise on the passenger side is sucky. It seems like its coming from the mid passenger side.... not from the strut.... but i could be wrong. I need to take a gander and see if the end link is broken or anything or CAB's are bad.
Seems to be a common issue.... anyone else have any ideas or had this same issue? Ii currently dont have a wheel key for my lug nuts... so until i get one i cant take my wheel off.
Old Jun 7, 2013 | 12:34 PM
Staged07SS's Avatar
Administrator
Administrator
I had a clunking sound. Started last year. Only when it rained. I started by changing the endlinks.
That worked for a bit, until the clunking came back, and found it was the CABs. Replaced the CABs. Now everything is mint.
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Bohb
Sep 27, 2015 09:11 PM
grampss
Sep 27, 2015 08:51 PM
