coilover install questions
Old Oct 5, 2014 | 03:46 PM
soaxin's Avatar
So I got d2racing coilovers and installed them but I don't think I have them installed right. The sway bar rattles like crazy. How far up should the end link adaptor be on the strut? I have it up so it's even with the end link when jacked up. By doing thathis I may have preloaded the springs. Should I put the adaptor up as high as it can go with no preload on the spring? Also on the rear should the perch be on top of the spring or the bottom. Search but didn't find info I could understand. Lol
Old Oct 5, 2014 | 04:37 PM
Sl0wbaltSS's Avatar
Take them to an alignment place, you should of had them install it to make sure there was no camber or toe.
Old Oct 5, 2014 | 06:29 PM
If your front sway bar rattles make sure the endlinks are torqued correctly
you take them there after the install and get an alignment...
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
