Coilover Issues
Old Jun 13, 2015 | 09:25 PM
footballplaya3k's Avatar
Coilover Issues
I've had a bad clunk coming from my driver side rear whenever I go bumps for the past few months, yesterday I finally figure it out. I thought it was a bad bushing but it ended up being my spring was sitting loosely with the suspension relaxed. I could easily move it around, it was not held firmly in place like it should be.
The only way I could see to fix this was by raising the ride height to eliminate the looseness with the suspension relaxed. This worked and eliminated the clunk but I had to raised my ride height up about a half inch and I don't like it.
Has anyone else had this problem? Any other way to fix this?
Old Jun 13, 2015 | 11:35 PM
06_ion2's Avatar
Maybe cut a donut shaped piece of rubber to go under the spring? See if that helps
Old Jun 14, 2015 | 12:46 AM
That would probably work, but that still would raise my ride height.
Old Jun 17, 2015 | 12:50 AM
Coilover Issues
Bump.
Old Jun 17, 2015 | 11:09 AM
keiserX13's Avatar
i have the same sound but haven't figured out what is causing it
thought it was my exhaust but that doesn't seam to move
interested on a fix
Old Jun 17, 2015 | 10:23 PM
Coilover Issues
I thought it was my exhaust at first too, then after eliminating that I thought it was bad trailing arm bushing until I accidentally found out it was the coilovers.
Old Jun 27, 2015 | 08:33 PM
kzak104's Avatar
you have bc coils? its normal for the springs to be loose when the car is lifted,
Old Jun 27, 2015 | 11:06 PM
Coilover Issues
They're Pedders but I think they're all similar. So does everyone with coilovers have this problem and just ignore it?
Old Jun 29, 2015 | 08:46 PM
keiserX13's Avatar
i dont hear the clunk anymore
Old Jun 29, 2015 | 09:15 PM
royce777's Avatar
your shock is loose
Old Jun 29, 2015 | 11:18 PM
Lose as in how? Excessive wear?
I didn't have this problem until I relaxed the dampening rate.
Loose as in how? Excessive wear?
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
