coilovers and bumpstops
Old May 23, 2010 | 08:22 AM
06cobalt racer's Avatar
so real quick. do you really need to keep the bumpstops when you have coilovers?? i would say that you dont need them since you can adjust the length of the shocks.
i understand why u need them with just lowering springs. the springs make the shocks sag.
but with coilovers the shocks still have full travel when its lowered. so any thoughts?
Old May 23, 2010 | 08:26 AM
rallyracer's Avatar
from what I've heard you need to keep them.
Old May 23, 2010 | 02:20 PM
Bumpin Balt's Avatar
You need them for any suspension setup. They keep the car from bottoming out hard. With CO's, you should cut them in half at least. What does it say in the CO instruction manual?
Old May 23, 2010 | 02:22 PM
fakameanrepresent's Avatar
you DON'T need the bump stop for coilovers setup, at least not mine. i have bump stop on the rear shocks itself, so why have 2 bump stops.
Old May 23, 2010 | 08:21 PM
Stamina's Avatar
I kept mine and just trimmed them up a bit.
Old May 23, 2010 | 08:23 PM
ls1fbody's Avatar
Haz l33t wheelz.
i didn't cut ****.
Old May 23, 2010 | 10:41 PM
tru2nrtt777's Avatar
If you have c/o's why are you talking about bumpstops or are you refering to adjustable sleeves and springs often called coilovers?
Old May 24, 2010 | 01:19 AM
Stamina's Avatar
The coilovers kits for our cars are different on the rear ones. They have a shock but have a separate spring that goes on a perch that replaces the stock one. The rear suspension's design wouldn't allow for a coilover similar to the front. We're talking about the bumpstop that goes on each end of the spring.
Old May 24, 2010 | 01:22 AM
chevy_cobalt_addict's Avatar
i took mine completely out lol
Old May 24, 2010 | 05:05 AM
yeah i dont see a reason to keep them in. like fakamean said the shocks have bumpstops on them so why do you need two?
Old May 24, 2010 | 06:36 AM
well the bumpstops are meant to work with the STOCK shock not a coilover shock. bottomoing out a coilover shock and bottoming out a stock shock is two different limits there cause the coilover shock is actually designed for lowering unlike the stocker
Old May 26, 2010 | 11:56 PM
exactly 06cobalt racer the bump stop on my coilover would hit before the stock bump stop would hit.
Old May 26, 2010 | 11:58 PM
ls1fbody's Avatar
Haz l33t wheelz.
Next time you say cut a bumpstop i'm gonna crawl through my modem and smack you.
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
PotatoLvrd
Sep 2, 2015 01:25 AM
