Coilovers, and things that go with low
Old Feb 19, 2013 | 06:04 PM
GreenySC2's Avatar
So i've been looking around here about going low, and i keep seeing things about locking rings in the coilovers? i have zero idea what those are..
And i have also noticed a rotated trans mount? whats the point behind this? can anyone explain show me before/after pictures of this mount? and best one to pick up
Old Feb 19, 2013 | 06:09 PM
turbosmart4's Avatar
Rotated mounts are made to align axles and to put less stress on them I believe, and also to get less wheel hop.
Old Feb 19, 2013 | 06:13 PM
Shortbus's Avatar
Locking rings are used to adjust the coilovers, most companys use a allen bolt to lock in the collar. Trans mount will help wheel hop.
Old Feb 19, 2013 | 06:20 PM
GreenySC2's Avatar
so the mount just helps keep axels in good state, and wheel hop(although i dont feel much as is humm) i swore i saw somewhere it helped with a clearance thing...
Old Feb 19, 2013 | 09:08 PM
kzak104's Avatar
people take the locking rings out of the rear to make it lower, its just a threaded insert thingy that allows you to adjust the height
Old Feb 19, 2013 | 09:09 PM
dakotaspeir's Avatar
#cobalthoes
if you arent low, remove a ring. I have no mounts and am fine. Also rack spacers is a common part of going low, but I dont use them
Old Feb 19, 2013 | 09:12 PM
Sox-Fan's Avatar
Got Brakes?
Everything you need to know about rotated mounts
https://www.cobaltss.net/forums/6935623-post64.html
Old Feb 19, 2013 | 09:25 PM
i have rotated mounts stg2 | rack spacers | ksport coilovers | moog endlinks
the lsj has bad hop from the start. no hop now expect the bounce from my rear
make tha ass bounce
Old Feb 19, 2013 | 10:21 PM
JAV119's Avatar
make tha ass bounce
What exactly are rack spacers if I may ask. Is rack the brand?
Old Feb 19, 2013 | 10:23 PM
Sox-Fan's Avatar
Got Brakes?
steering rack.
When you lower your car you change the tie rod end angles, inducing bump steer. Rack spacers help restore that angle and remove the bump steer.
Old Feb 19, 2013 | 10:25 PM
JAV119's Avatar
Originally Posted by Sox-Fan
steering rack.
Ohhhh okay thanks man, do u know of a good place that sells them, I'm planning on lowering my car soon.
Old Feb 19, 2013 | 10:28 PM
i think powell has the hook up on them as well
Steering Rack Spacers
Old Feb 19, 2013 | 10:30 PM
steering rack.
this, i left out steering hehe
Old Feb 19, 2013 | 10:32 PM
JAV119's Avatar
That's not bad I was expecting it to be a lot more for some reason.
Old Feb 19, 2013 | 10:36 PM
Sox-Fan's Avatar
Got Brakes?
John Powell sells steering spacers, though you'll need to know how low you plan on going so that you can get appropriately sized spacers. If you get the one size fits all version you stand somewhat of a chance of making it worse. And to be honest, unless you're really going amazingly low you'll probably not even notice it. Your tire wear will though.
Old Feb 19, 2013 | 10:42 PM
JAV119's Avatar
Yea I saw on the website it asking how much the car was lowered, at this point i have to wait to lower first
Old Feb 21, 2013 | 06:17 PM
GreenySC2's Avatar
after some looking and some reading, looks like the trans mount helps in the end, nothing major but it'll help so good investment in the low process just cause, as the spacers go, they have a .5" difference so if you get springs thats an easy choice, but with coilovers i'd get those first and see what your comfortable with as far as low goes then order...
Old Mar 18, 2013 | 10:23 PM
JAV119's Avatar
In regards to the steering rack spacers will one set be sufficient. I believe it may be a pair that you buy or is it single
Old Mar 19, 2013 | 12:17 PM
its a two spacers one for each side of the steering rack
Old Mar 19, 2013 | 10:32 PM
JAV119's Avatar
Thank you sir
Old Apr 16, 2013 | 02:17 PM
GreenySC2's Avatar
i heard somewhere about the 5mm spacers that crate engine has helps when you go low, is this true?
per the rack spacers i might just order 1"-2" and the 2"+ set just to be safe and i never know if i'll adjust it or not..
Old Apr 16, 2013 | 02:27 PM
the 5mm spacers are for clearance of the brembo calipers, u can use them low or not
mainly the brembo guys run them to gain the space
i have them in the front to have some clearance on my struts as im low and have some camber
Old Apr 16, 2013 | 02:30 PM
GreenySC2's Avatar
yeah i was thinking about maybe throwing in some camber when i go low...
so theres no need to get them all around? just the fronts?
Old Apr 16, 2013 | 02:39 PM
they are a bit pricey and i only really needed the front haha
if u want them all around it will give it more of an agressive look, subtle as 5mm isnt that much
Old Apr 16, 2013 | 02:43 PM
GreenySC2's Avatar
humm well i was going to jack the PN off crate engine, along with the numbers for the extended lug bolts, and go through my dads work to get them...
it sounds like it'll look alright with some camber and a bit of space... so long as i dont go so low to where i need to roll the fenders...
oh and if it helps i am looking at getting the Megan street coilovers?
