Coils binding
Old Oct 3, 2017 | 11:55 AM
cobaltssdude420's Avatar
Coils binding
Anyone here on coilovers? Small issue when turning specifically on the passenger side. It sounds like the actual coils popping rather than the axles binding...will try raising them an inch at a time but any input would be great
Old Oct 3, 2017 | 11:58 AM
royce777's Avatar
what coils? you sure everything is tight? locking rings tight, camber plate bolts tight, etc.
Old Oct 3, 2017 | 03:27 PM
HSD. They are about 2 inches from being bottomed out and everything is nice and tight
Old Oct 4, 2017 | 08:46 AM
royce777's Avatar
I saw a FB post where a guy with HSD coils, the strut shaft broke from the entire lower strut body.
Old Oct 4, 2017 | 11:27 AM
Yeah it doesn’t sound too good lol. Sounds like something is about to break on me
Old Oct 4, 2017 | 11:38 AM
royce777's Avatar
take it part and see if the same happened to yours.
Old Oct 4, 2017 | 12:23 PM
I can’t remember if we pre loaded them or not. We swapped my rear axle assembly at the same time so I was pretty tired lol. Maybe I’ll do that and see what happens first
Old Oct 8, 2017 | 03:48 AM
Adjusted preload and tried playing with the camber on these coils a bit. Passenger side still creeks but no near as bad now.
Old Oct 8, 2017 | 10:10 AM
royce777's Avatar
you shouldn't have to adjust the preload. unless you messed with the spring and upper locking rings. the height adjustment is on the lower knuckle piece.
Old Oct 8, 2017 | 11:11 AM
I never pre loaded them at all before. It’s half as annoying now lol. I know how to adjust the height
Old Oct 8, 2017 | 12:47 PM
royce777's Avatar
they should come preloaded already. the fronts that is
Old Oct 8, 2017 | 01:18 PM
I got them off a buddy
Old Oct 13, 2017 | 10:23 PM
Not sure what the pivot part is called at the top of the coil but all I did was grease it and it’s fine now lol. For some reason there was a bit of movement causing it to sound like the coil was popping
