difference between 225 and 215
Old Nov 1, 2005 | 09:10 PM
hardtocope's Avatar
quick question. does a 225/40/18 tire add more protection on a rim that a 215/40/18?
Old Nov 1, 2005 | 09:15 PM
Cobalt_Supercharged's Avatar
Check out these sites.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old Nov 1, 2005 | 09:48 PM
madmike8's Avatar
I think I've answered this for you before... but here we go again... a 215/40/18 has a 3.4" height sidewall... a 225/40/18 has a 3.5" sidewall... so it only adds .1" so it add's very little if any...
Originally Posted by madmike8
215 is the width... not the height of the sidewall... 40,45,50 thats the height... It's called aspect ratio... basically the aspect ratio is a percentage of the width... so a 215/45/17 tire will be 215mm wide the sidewall height will be 45% of the width. 215 x .45 = 96.75mm To get inches divide by 25.4... so that tire will have a 3.8" sidewall height...
Old Nov 1, 2005 | 09:50 PM
hardtocope's Avatar
thanks guys.. sorry to bother you but i really appreciate your help that you have offered me..
Old Nov 1, 2005 | 10:17 PM
Don't worry about it. That's why there are boards.
Old Nov 1, 2005 | 10:56 PM
myoshizawa819's Avatar
The factory Rosso's have a rim protection lip on them. Don't know how well it works and I don't care to find out.
Old Nov 2, 2005 | 12:05 AM
zinner's Avatar
Moderator Alumni
Works good I have bumped a curb pretty hard and the rim was ok
Old Nov 2, 2005 | 12:13 PM
JapEatr's Avatar
South Central *********
i just put 225/40/18 on, let me tell you, these should be the production tires...much better
but i wouldnt go 235s unless not lowering your car
Old Nov 3, 2005 | 10:28 PM
BlAckOnBLaCK's Avatar
What tire did you go with? Do you have any pics? Just wonderin if I should go with either 225 or 235. Another guy put on 235 and they lookes pretty good.
Old Nov 9, 2005 | 02:23 PM
n4ggs's Avatar
a 225 tire will stick out laterally relative to the rim. it will protect the rim better than 215.
Old Nov 14, 2005 | 06:54 PM
Erod's Avatar
Moderator Alumni
https://www.cobaltss.net/forums/wheels-tires-96/wheel-fitment-f-q-stock-wheel-f-q-how-get-wheels-your-cobalt-read-me-8149/
turbochargedss2012
Sep 20, 2023 12:17 PM
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
