Difference between FE3/FE5 rack and pinion vs FE1
Old Jun 13, 2011 | 01:14 PM
06BaltCoupeLT's Avatar
Ok, ever since i had my cobalt it has taken atleast twice the effort to turn the wheel when making right turns. I suspected that it was the powersteering motor but after the dealer replaced it due to the recall it didnt help. The service guy mentioned it might be the rack and pinion since it was in an accident and hit on the driver side.
So..my question is what is the difference in the rack in pinion between the FE1 (soft ride) vs FE3 / FE5 (sport suspension) cause for some reason the FE3 / FE5 rack and pinion is $ 100 cheaper than the FE1 and if its better and will fit ill buy it. According to the sticky in the Suspension section it seems like it might work.
Please HELP !!
Old Jun 13, 2011 | 09:14 PM
Powell Race Parts's Avatar
none. they are all the same. its the knuckle steering arm is different. Buy the cheapest one from CED good luck with your ride
Old Jun 15, 2011 | 05:51 PM
Thank You !!! hope it fixes the problem.
Old Jun 15, 2011 | 08:09 PM
^^^ let us know how it all works out 4 u. cheers!
Old May 24, 2021 | 03:51 PM
Shannon215's Avatar
whats the diff between with or without soft ride suspension?
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
