dot 5 silicone brake fluid?
Finally got a reply from Motive Products. The 0108 adaptor is a direct screw/twist on cap for the Cobalt. My problem was nobodys application sheets went beyond 07. Pressure bleeder ordered. Hook, line, sinker. DONE!
Thanks again.
Thanks again.
Don't crank it up too much when you're using it! IIRC, it only takes like 15 psi. If you crank it up too much, you risk splitting the plastic reservoir, which is not designed to handle being pressurized.
Let us know how you like it. I sold my Motive bleeder years ago when they didn't have caps that fit anything other than German, and you had to use the crap ass J hooks. After a few brake fluids spills, I got tired of it.
