View Poll Results: EIBACH VS PROGRESS?
eibach
93.75%
progress
6.25%
Voters: 48. You may not vote on this poll
Eibach Vs Progress?
Old Apr 8, 2009 | 11:27 PM
NWAE Cobalt's Avatar
gm parts direct, about 360$ for a full set (including the front being a full strut assembly not just the strut needing modification)
i have them on my car with h&r sport racing springs
handels like a dream and wasnt too expensive
Old Apr 8, 2009 | 11:28 PM
SedanMan08's Avatar
gmpartsdirect.com i believe. someone EDIT this if im wrong.
Old Apr 8, 2009 | 11:29 PM
SedanMan08's Avatar
Old Apr 8, 2009 | 11:36 PM
Old Apr 8, 2009 | 11:40 PM
ctcsoccer7's Avatar
so let me see if im getting this correct....if you buy the SS/SC or SS/TC springs you can put those on your base or LT cobalt ....correct? and it will lower it? hoe much lower if this is correct?
Old Apr 8, 2009 | 11:52 PM
not a whole lot, but it handels ALOT better and will work better longer with lowering springs
yes though, it does bolt right up
Old Apr 8, 2009 | 11:54 PM
SedanMan08's Avatar
we're not talking about the ss/tc lowering springs they'll lower your base model balt about 1.5-1.25 i believe not much. you want the STRUTS/SHOCKS from the SS/TC the SS model cobalts are already lowered from factory so there already made for a lowered car. Buying the SS/TC SHOCKS/STRUTS will save you quite a bit.
ctcsoccer7's Avatar
ok so if im looking for a better feel and look with out droping to much FE5's would work right?
Old Apr 8, 2009 | 11:55 PM
ChriSS/SC's Avatar
I think Eibach is winning...
Old Apr 8, 2009 | 11:56 PM
  #36
ctcsoccer7's Avatar
i would have to agree! 100 percent!
Old Apr 8, 2009 | 11:59 PM
  #37
yes, although make sure its the ss/TC strut not the ss/SC strut, the sc strut is still better, but not as good as the tc strut
and it will lower you a little, but is meant to be coupled with a lowering spring to get the actual height difference
Old Apr 9, 2009 | 12:03 AM
  #38
ctcsoccer7's Avatar
sweet so TC gotcha! if i find a TC with factory springs that will lower it as well , but your suggestion is to couple it will some lowering springs for height
Old Apr 9, 2009 | 12:10 AM
  #39
yes and yes
check into the 2.2 l61 section or under the suspension sticky for the 2.2 suspension topic, there is als o a review by me (check my threads to see) about tc install (with pics)
Old Apr 9, 2009 | 12:11 AM
  #40
ctcsoccer7's Avatar
yes and yes
thanks for the help!
Old Apr 9, 2009 | 12:12 AM
  #41
np man, let me/us know if you need any help
Old Apr 9, 2009 | 01:57 AM
  #42
Omnigear's Avatar
https://www.cobaltss.net/forums/show...7&postcount=72
my car on arks springs
Old Apr 9, 2009 | 02:26 AM
  #43
Boosted_Cobalt09's Avatar
^^^^how do they ride because i hear their coilovers are garbage so im curious about the springs.?????
i voted eibach even though i dont like their springs.
Last edited by Boosted_Cobalt09; Apr 9, 2009 at 02:26 AM. Reason: Automerged Doublepost
Old Apr 9, 2009 | 02:27 AM
  #44
Omnigear's Avatar
like any springs pretty much
rough if stock is 1 then the springs
i have now in my opinion is 3-4
well everyone liked it so far.
Old Apr 9, 2009 | 02:32 AM
  #45
Angel's Avatar
H+R over Eibach any day. German engineering. My car rides so much better with H+R's over the balts Ive rod in with the bachs..
Old Apr 9, 2009 | 02:33 AM
  #46
dman090's Avatar
i love my sportlines
Old Apr 9, 2009 | 08:03 AM
  #47
Bumpin Balt's Avatar
I have Progress springs and the ride quality is better than stock unless you hit a really big bump. The rear springs are a bit short though. The back end sits low unless you do something like this:
I made 3/4" shims to lift the back of the car. They are made out of a PVC material called AZEC. I have about 150lbs. of stereo gear in the trunk, but I don't think that should make the back squat as much as it did without the shims.
Before:
After adding 3/4" shims:
Old Apr 9, 2009 | 08:39 PM
  #48
lumbad's Avatar
i ahve the progress as well and i love the way they ride. definitely a little stiffer than stock but the handling is great. i did not have the problem with an uneven stance, my sits perfect, same gap over both wheels.
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
Haily229
Sep 17, 2015 07:18 AM
thewafflesareburnt
Aug 29, 2015 11:38 PM
