Emergency Brake
Old Jun 23, 2013 | 07:37 PM
Chaos_Six's Avatar
Emergency Brake
I've searched high and low for the solution to this problem. I've been lurking here for a long time and have always found topics for what I'm doing. Hence my low post count. Either way, a few weeks ago I pulled up on my E brake and the cable snapped. I was unsure where until I took apart the center console. The little cone at the end of the cable (the piece that sits in the bracket) ripped right off. How in the world do I go about replacing this? A new e brake cable? I know a lot, but when it comes to e brakes, well lets just say I'm not that great. I don't even know how they work on this car without having drums in the rear...
Any input would be awesome. Thanks guys.
EDIT: Also, pics can be uploaded if needed.
Last edited by Chaos_Six; Jun 23, 2013 at 07:39 PM. Reason: I suck at the internet
Old Jun 23, 2013 | 08:00 PM
thejoey12's Avatar
Mine did this about a month back ...you will need to purchase the cable from the dealership they were $20 a piece ....they are very easy to replace ....just jack the rear side that snapped off, take the tire off and remove the cable out of the caliper and PFF the car and replace. Once you've jacked it up and pulled the tire off just follow the line. It literally took me 10 minutes to replace both sides. Oh and don't let the dealership tell you anything different all you need is that cable
Old Jun 24, 2013 | 12:39 PM
Chaos_Six's Avatar
So once the cable is free from the caliper do I just pull it out and i can slide the new one in?
Old Jul 1, 2013 | 09:47 PM
thejoey12's Avatar
yup..like I said its easier than you think
Old Oct 15, 2013 | 08:31 PM
jaygo7007's Avatar
this just happened to me while i was working today. one cable snapped completely while the other is just completely useless. im not brake savvy so i called the local pep boy store to get a estimate on the repair and i was told only the dealer can install this part. is this true? well obviously no since thejoey12 did his at home...
Old Oct 26, 2013 | 02:08 AM
thejoey12's Avatar
Noo man do it yourself like I said get under it and follow the line...the only hard part is getting it onto the handle and the actual caliper
Old Oct 26, 2013 | 02:16 AM
Spawne32's Avatar
i had a problem with mine but it turned out the bracket that holds the cables in ripped off, i gotta replace the entire handle assembly.
Old Nov 1, 2013 | 03:08 PM
victoryredbalt06SC's Avatar
Hey guys don't mean to thread jack but while on thee brake subject mine works but won't lick when I pull it up. Any suggestions?
Old Nov 4, 2013 | 09:09 AM
thejoey12's Avatar
Pull the center console apart and see if everything is connected. Also can you post a pic of the insides when you pull it apart
Old Nov 4, 2013 | 02:54 PM
yea I can it works like I can pull it up abd it will work just won't lock into place
Old Nov 4, 2013 | 03:15 PM
thejoey12's Avatar
Then yeah you are probably looking at a new part
Old Nov 4, 2013 | 03:33 PM
yellowsupercharged06's Avatar
message Tom @ Crate Engine Depot .... he will hook you up with the correct parts.
Old Nov 4, 2013 | 03:54 PM
Thanks guys!
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
