Engine Cradle Removal
I'm in the process of removing the transmission, and thus the engine cradle. I have the 4 corner bolts unbolted, the exhaust downpipe bolts, the front mount, the radiator unbolted, and removed the control arms and sway bar mounts. Can anyone think of what I'm missing?
The front and rear trans mounts both need to come off too. Also, the steering rack to steering column needs to be disconnected/dislodged.
I'm not sure what exhaust downpipe bolts you're referring to. If you have a SS TC, the DP stays put...
nevermind found this
http://www.gmperformancedivision.com...J_Chap_1&2.pdf
http://www.gmperformancedivision.com...SJ_Chap5&6.pdf
patooyee
Oct 1, 2015 01:07 PM
