FE3 Cobalt Suspension same as G8 Suspension?
Old Apr 26, 2009 | 05:59 PM
recklessactn's Avatar
I was watching a review on the G8 GXP and the rep from GM said the suspension on the G8 was the FE3 suspension. Is this the same set up that the 2.4 cobalt had with some adjustments I'm guessing or is it a completely different set up with the name carrying over.
Heres the vid http://www.youtube.com/watch?v=9_4melfsbJ4
Old Apr 26, 2009 | 06:11 PM
emiller's Avatar
The setup is not the same its just the rating system GM uses. Basically they go FE1 (least sporty) to FE5 (most sporty).
https://www.cobaltss.net/forums/suspension-67/suspension-brake-facts-fe1-fe3-fe5-j41-jm4-jl9-137064/
The suspensions:
Starting with the FE1, and then the changes with each up-level system
FE1 suspension
19-mm front stabilizer bar
16-mm rear stabilizer bar
Stamped steel front lower control arms
FE3 suspension
22-mm front and rear stabilizer bars
Cast aluminum front lower control arms
FE3 shocks and springs
FE5 suspension - 2005-07 years
24-mm front stabilizer bar
FE5 shocks and struts. The springs may be different from some FE3 models.
Larger front end links
FE5 suspension - 2008 and up years
24-mm rear stabilizer bar
NEW FE5(LNF) shocks, struts, and springs.
Updated front knuckle
Old Apr 26, 2009 | 06:35 PM
Maven's Avatar
OMFG......did you really just ask this Aviator?
The G8 is a large 4whl independent suspension rear wheel drive vehicle. The Cobalt is a compact with a semi independent twisting beam and front wheel drive.
No its not the same, its just the same RPO code.
Old Apr 26, 2009 | 08:27 PM
Hahaha thank you maven... Was just a bit curious you know as too why he said that.
chefhhr
Oct 26, 2015 10:36 PM
Cptnslo
Sep 24, 2015 09:32 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
jthwjde
Sep 7, 2015 09:24 AM
