FE3 Links dead, replace to FE5? Possible?
Old Mar 28, 2011 | 11:13 PM
07BoostedG5's Avatar
Originally Posted by Trent
is there a shape difference in the sway bar? -If there isn't then we should be able to use the FE5 links.. BUT, on the FE3, the links connect to the strut higher up near the tower, and I'm not sure where the FE5 connects to the strut.
No difference in shape, just the obvious bar thickness.
Old Mar 29, 2011 | 09:38 AM
Trent's Avatar
Well this is good news! I only installed one link, so maybe if they'll let me I'll bring them both back and swap for the better (and cheaper) FE5 links! Thanks all!
Old Mar 29, 2011 | 09:58 AM
CordiaDOHC's Avatar
Yeah get the FE5 links.
I have the FE5 Moogs on my FE3 car. It was worth the money.
Heres my thread on them
https://www.cobaltss.net/forums/susp...dlinks-203703/
Old Mar 29, 2011 | 10:51 AM
This is a good read too
https://www.cobaltss.net/forums/susp...nswers-149527/
Old Mar 29, 2011 | 04:56 PM
toolman's Avatar
Really? This is good news to hear! After replacing my Links, I noticed that there is tension on the sway bar (never replaced one before, so this is new knowledge ), since the FE5 links are shorter, how much tension did you have to put on the links to make the bar move up to the mount on the strut?
Originally Posted by shredout
i used the FE3 links, unfortunately. they are quite long. i put a wrench between the sub frame and the sway bar and pressed the sawy bar down untill i could fit both ends of the link in. twas quite a pain.
If you put the whole front end up on blocks and disconnect both end links, you won't have to try to bend the swaybar. It'll just swing into position.
Old Mar 29, 2011 | 06:06 PM
shredout's Avatar
that would have been a better approach. i was on the side of the road though, and only had one jackstand in my trunk. lol
Old Mar 29, 2011 | 07:11 PM
Trent's Avatar
I did one side so far, definitely lifting and setting next time! I read up on the threads you guys provided.. sweet stuff! Thx!
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
Coballin13
Sep 25, 2015 08:43 AM
