fuckin rear brakes
Old Mar 13, 2011 | 10:46 PM
ufnwish's Avatar
****** rear brakes
can i put a rear brake setup from a 06 ss on my 08 or what seems to be the best setup for the 08
Old Mar 13, 2011 | 10:50 PM
redcobalt07's Avatar
You'd have to swap the entire axle.
Old Mar 13, 2011 | 10:54 PM
Malaclypse's Avatar
Have fun with that. The brakes on the '08 SS are FAR better than the '06. Case in point, rear rotors on '08 are vented, '06 are solid.
Just change pads away from factory and try again.
Old Mar 13, 2011 | 10:57 PM
ufnwish's Avatar
thanks good to know i never had a problem with my 06 but the 08 has trashed 2 sets roters and 1 set of pads at 25 k
Old Mar 13, 2011 | 10:59 PM
Garret's Avatar
Dont swear in your titles anymore.
Oem replacements are good obviously. Hawk hps pads lots of people are running. Also r1 concepts rotors a lot of people use
Old Mar 13, 2011 | 11:00 PM
ufnwish's Avatar
that will be the way i go but what setup works best hawk pads on stock or sloted
cobaltltblue's Avatar
look at my R1 concept install and /thread.
Old Mar 13, 2011 | 11:02 PM
07SSYellow's Avatar
Resident Post Whore/Troll
my rear brake are being replaced here shortly under warranty because the slide pin stuck and trashed my rear brakes, getting new calipers, pads, and rotors
Old Mar 13, 2011 | 11:05 PM
ronn's Avatar
I changed my pads and rotors for $150 total. Rock Auto on line. Centric Premium Plain rotors and Wagner Thermoquiet Ceramics (Saab Pads).
Old Mar 13, 2011 | 11:06 PM
ufnwish's Avatar
oh no not for me brakes run out at 24 k so im sol starting to think the only thing that the 3/36 covers is the gas cap well maybe not
Old Mar 13, 2011 | 11:07 PM
TommyP's Avatar
AWD > FWD
Make sure your brakes are WELL lubed. Get new rotors (smooth is best), and get OEM pads if you want the best stopping strength. If you're more concerned with preventing dust, get hawk hps. I bought drilled/slotted, and hawk hps, and I wish I had stuck with stock. I like how the hps pads don't dust, but they don't stop NEARLY as good as stock, and I wish I still had smooth rotors because I'm afraid of my drilled ones cracking if I do a track day or two. They do look good though. The stock pads are fine as long as the brakes are lubed, although a stronger rotor is a better idea.
ronn's Avatar
Better hope you don't get same pads..that's the problem. Make sure they are using a different pad material.
ufnwish's Avatar
how long has that setup worked for you?
Old Mar 13, 2011 | 11:10 PM
ufnwish's Avatar
im just needing rear setup here my fronts are fine got the replacement roters at 3 k all good
07SSYellow's Avatar
will do ronn thanks for the info bro!
Old Mar 13, 2011 | 11:17 PM
ronn's Avatar
Last couple K Mi...no problems...rotors are still like new.
Old Mar 13, 2011 | 11:26 PM
ronn's Avatar
This is stock..the ones I had taken off:
Cobalt 2008 - 2009 SS/TC OEM Rear Brake Pads 15271565 - Crate Engine Depot
Old Mar 13, 2011 | 11:47 PM
07SSYellow's Avatar
awesome bro ill keep an eye on them
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
