Grinding/humming/thumping noise
Old Feb 14, 2010 | 05:38 PM
blackrocky's Avatar
guys i have a problem!!!!
Im hearing grinding/humming/thumping noise coming from the front end of my car. The noise only occur between 0-40 mph, Im positive that its not the axles. To me these symptoms sound like a bad wheel bearing. I need some feedback!!!!!!!!
Old Feb 14, 2010 | 05:57 PM
blackbolt89's Avatar
i have the same thing. i can only hear it when im cruising at around 35 mph on a smoothish road. sounds like someone knocking on the subframe or seomthing.
my vote is wheel bearing. but it may be the ball joint? who knows.
Old Feb 14, 2010 | 06:03 PM
qwikredline's Avatar
wheel bearing is a good bet...
Old Feb 14, 2010 | 06:47 PM
blackrocky's Avatar
Being tuned in all do u think the dealer would give me any problem?
Old Feb 15, 2010 | 11:42 AM
TCguy's Avatar
Being tuned has to deal with your Powertrain, since your concern is suspension wise, no, they should not give you any issues
Old Feb 17, 2010 | 03:17 AM
100% METH's Avatar
Having the same issue!
It makes the car's front end sound like the tires are off, and the wheels are rolling bare. The faster you go, the louder it gets and the more thumping n vibe it has.
I have slowly been getting the thumping symptoms, but after a good canyon run last night. I started getting everything you described.
Old Feb 17, 2010 | 10:10 AM
tmharsh's Avatar
Get the car going at the speed where the sound is the loudest and then quickly swerve from one side of the road to the other. If there is a distinct stop in the noise when turning in a particular direction, then that would indicate a bad wheel bearing. When you put load on the bad one it should get louder and quieter when you decrease load on it. So if you turn left and it gets louder and quieter when you turn right, that would indicate a bad left wheel bearing.
Old Feb 17, 2010 | 12:38 PM
blackrocky's Avatar
is it safe to drive on?
Old Feb 17, 2010 | 12:55 PM
Terminator2's Avatar
It should be safe for a little while but I would get it to the dealership ASAP.
Old Feb 17, 2010 | 03:47 PM
100% METH's Avatar
I hear it turning left and right.
More so when I acelerate
Old Feb 17, 2010 | 04:05 PM
09blackonblack's Avatar
in for an answer but.... check your lca bushings... my left front has play in it which lets the left front tire move like a bad wheel bearing. my bearings checked out fine.
Old Feb 18, 2010 | 10:23 AM
is it possible for the wheel bearings to be bad but not have play?
Old Feb 18, 2010 | 09:53 PM
SSchargedSS's Avatar
yes.
Old Feb 18, 2010 | 09:57 PM
tmharsh's Avatar
Does the sound go away coasting in neutral or is it still there?
Old Feb 18, 2010 | 11:54 PM
100% METH's Avatar
yeah the vibes n grinding sound go away
though the car still doesn't feel 100%
Old Feb 19, 2010 | 08:52 AM
tmharsh's Avatar
Well, if the sound goes away when coasting in neutral then it's not a wheel bearing, which are still in use in neutral. Sounding more like a transmission related issue.
Old Feb 19, 2010 | 09:43 AM
then i will have to pull them off and check them better. my car does it at 55+ and makes a whiney/whistle sound when driving under 30 put if i push in the clutch it stops.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
