HELP HELP HELP Control arms how to guide WHERE
I got a 2007 Cobalt LT I need a how to guide on replacing control arms I got the left and right control arms with ball joints in today and would really like to replace mine so my ride isn't crap anymore please someone point me to a how to guide asap )=
lug nuts: 100 ft-lbs
the two bolts in the middle for the Leading control arm bushing: 41 ft-lbs
the rear control arm bushing: 74 ft-lbs + another half turn
ball joint bolt: 37 ft-lbs, loosen 3/4 turn, then 37 ft-lbs again plus 30 degrees
let me know if you need more help
About the ball jiont connection: after you remove the bolt from the ball joint, put a big screw driver or a big chisel in the gap and force the gap larger. If you do this, you can simply wiggle the hub and it will let the LCA 'fall out' -- no hammers required -- it's really easy. When you put the bolt back in (after you're done with the LCA), the torque process is that you torque the bolt, then loosen the bolt about 3/4 turn, and finally re-torque to spec (oops, I see that torque process was already described -- sorry about being redundant).
I've swapped LCAs more than once...
Scott
Scott
