HELP HELP HELP Control arms how to guide WHERE
Old 05-21-2012, 08:52 PM
serge183's Avatar
I got a 2007 Cobalt LT I need a how to guide on replacing control arms I got the left and right control arms with ball joints in today and would really like to replace mine so my ride isn't crap anymore please someone point me to a how to guide asap )=
Old 05-21-2012, 10:11 PM
BLKLS's Avatar
Lol, get the front end off the ground, it's three bolts, unbolt them beat the ball joint out with a big hammer, install the new one.
Old 05-22-2012, 06:03 AM
06cobalt racer's Avatar
Yeah it's really easy and I think there is a how to on the site for it. But, there is a big bolt in the back, 2 bolts in the middle of it and the ball joint bolt. It is really really easy.
Old 05-22-2012, 06:02 PM
serge183's Avatar
Thanks a lot for the help ok one more question do I not even have to take the tire off might be a dumb ? but .... lol
Old 05-22-2012, 06:04 PM
BLKLS's Avatar
Technically I don't think so, but I strongly recommend it. :-)
Old 05-22-2012, 06:10 PM
tpete763's Avatar
It'll be hard to get to the ball joint bolt if you don't.
Old 05-22-2012, 06:55 PM
It will be much easier if you do. Idk if it has been done with the wheel on
Old 05-23-2012, 03:09 AM
Crav3's Avatar
Do the bolts have to be tightened to certain lbs of torque?
Old 05-23-2012, 08:34 AM
lug nuts: 100 ft-lbs
the two bolts in the middle for the Leading control arm bushing: 41 ft-lbs
the rear control arm bushing: 74 ft-lbs + another half turn
ball joint bolt: 37 ft-lbs, loosen 3/4 turn, then 37 ft-lbs again plus 30 degrees
let me know if you need more help
Old 05-23-2012, 12:58 PM
scottherbert's Avatar
About the ball jiont connection: after you remove the bolt from the ball joint, put a big screw driver or a big chisel in the gap and force the gap larger. If you do this, you can simply wiggle the hub and it will let the LCA 'fall out' -- no hammers required -- it's really easy. When you put the bolt back in (after you're done with the LCA), the torque process is that you torque the bolt, then loosen the bolt about 3/4 turn, and finally re-torque to spec (oops, I see that torque process was already described -- sorry about being redundant).
I've swapped LCAs more than once...
Scott
yellow dragon
09-28-2015 09:49 PM
Trav3480
09-28-2015 02:46 PM
metroplex
09-27-2015 07:48 AM
09-26-2015 06:44 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: HELP HELP HELP Control arms how to guide WHERE
