Help Rear Caliper Need Help Right Now!
Old Dec 8, 2008 | 06:28 PM
eurochevy's Avatar
k my rear caliper doesn't wanna go back in the piston..tried a c-clamp it won't go back in..im changing brake pads and **** should i just open up the bleeder screw and then try pushing it back?.. HELP
EDIT! = solution = twist it back with needle nose pliers clockwise!, thx to doc in other thread that he doesn't even know of probably and members in this thread
Old Dec 8, 2008 | 06:30 PM
D4u2s0t's Avatar
you need a special tool for the rears. if you do it without the tool you will damage something. put the old ones back on, they should fit, and wait till you have the tool to change it. look in the how to for specifics about the tool.
eurochevy's Avatar
oh my ******* god u need a friggen tool?! link to this how-to plz..i just got pissed off now...
Old Dec 8, 2008 | 06:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yep the rears screw in, they dont push in. the tool looks like a little cube with a hole for a socket extension at the end of it
Old Dec 8, 2008 | 06:38 PM
jefferyss's Avatar
Take The Shims Out Of The Pads You Just Replaced...that Should Free Up Some Room
Old Dec 8, 2008 | 07:12 PM
Cobaltxfe09's Avatar
just be carefull not to rip the rubber boot around the piston and twist it back with some pliers or somthing. that always worked for me on my other cars
Old Dec 8, 2008 | 07:20 PM
Maven's Avatar
You can twist the piston back in by using a pair of needle nose pliers usually. Use the pliers to grip the little notches and rotate the piston back in.
This is the cheap version of the tool you need: http://www.sears.com/shc/s/p_10153_1...0070921x00003a
Get it at any auto parts store
Old Dec 8, 2008 | 07:59 PM
eurochevy's Avatar
yep thanks guys i used needle nose pliers and just twisted them back ...thx guys
btw.. i forgot to wash the rotors before i put them on .. i just slapped everything on and went to make sure they work and went driving around and braking randomly to break it in a bit before i take it easy on it..my cuz called and said i had ot wash them with solvent or else the **** will get on my pads and etc etc etc..but if it all burns off who gives a **** it means its gone right? like my front right rotor was smoking for a while which means that the gloss was going is that a good thing or bad thing?
Old Dec 8, 2008 | 08:18 PM
well i know when i put on new rotors i would clean the with brake cleaner and an emery cloth/or sand paper and spray them again so never had them glaze on me so someone else will have to chime in on that
Old Dec 8, 2008 | 10:21 PM
Maven's Avatar
Its good practice to always wash your rotors with soap and water when using new or freshly cut rotors.
If they have an oily/waxy/greasy coating on them you should definitely clean this off or you could possibly contaminate the pads and reduce how well the brakes work
Old Dec 9, 2008 | 01:23 AM
jefferyss's Avatar
never knew that...good post
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
