How to install Eibachs
Well depending on what tools you have depends on how long it will take. It took me and my friend about 45minutes to do all 4. Due to the fact there was 2 of us, a lift, air tools and a wall mount spring compressor. But my previous car i didnt have all of that and it took a couple hours to do. Not a very hard installation at all. but yes the rears are much easier than than the fronts
^ there are no adjustments....just replacing the springs. Besides aligning if your car needs an alignment (mine didnt) and dont forget to cut them bump stops!
my car sits pretty level with the sportlines on now. dont know if you just do rears.
Originally Posted by cobaltjohnny
what if we just do the rears the car will be level then cause its pretty high back there?
Originally Posted by scotts2.0
Lookin to install my own sportlines on an SS/SC. Has anyone done a how to on this? Does is require a spring compressor and how long should it take?
thanks
thanks
There's a pretty good write up on here somehwere just got search for it. For me installation took 2 hours and thats from when I pulled into my garage to when I pulled out. Rear took no joke maybe 20 minutes. Used hand tools for the rear and air gun for the fronts.
Originally Posted by uthinkimodd
i'll probally get me some in about a month and i've got a great place to do the picture thing and write up but if somone wants to beat me to it be my guest
A good write up would be a great addition to this forum, for those who are unsure about what it will take to do this mod it might be a good idea to wait for such a write up.
Off topic some what, Here's what I mean by a good write up ( sorry not a lowering spring install write up ) http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm , that's the kind of write up I'd like to see for the lowering springs.
https://www.cobaltss.net/forums/suspension-67/spring-installation-18488/
Second post down is the write up i was talking about.
in any case, i'd also like to see a really detailed how-to for the springs with tons of pictures. i always get leary using a spring compressor. one slip and the spring just went through your face.
That's one very important part of a good write when it comes to installing springs, as I was quoted in the write up.... Here I would like to add safety is #1 because dead guys can't work on cars.
Delta coupe
Sep 30, 2015 08:11 AM
