How to install Eibachs
Old May 23, 2006 | 05:35 PM
scotts2.0's Avatar
Lookin to install my own sportlines on an SS/SC. Has anyone done a how to on this? Does is require a spring compressor and how long should it take?
thanks
Old May 23, 2006 | 05:37 PM
BlackSS05's Avatar
most peopel say that the rears are really easy and take about 45 mins and yes you WILL need a spring compressor. they say that the front is really difficult however so irdk.
Old May 23, 2006 | 06:14 PM
PlaysWitCars's Avatar
Former Cobalt Owner
Well depending on what tools you have depends on how long it will take. It took me and my friend about 45minutes to do all 4. Due to the fact there was 2 of us, a lift, air tools and a wall mount spring compressor. But my previous car i didnt have all of that and it took a couple hours to do. Not a very hard installation at all. but yes the rears are much easier than than the fronts
Old May 23, 2006 | 06:21 PM
cobaltjohnny's Avatar
what if we just do the rears the car will be level then cause its pretty high back there?
Old May 23, 2006 | 06:33 PM
T Dawg's Avatar
is it swap and go or is there some adjustments? I've never done suspension.
Old May 23, 2006 | 06:48 PM
Former Cobalt Owner
^ there are no adjustments....just replacing the springs. Besides aligning if your car needs an alignment (mine didnt) and dont forget to cut them bump stops!
my car sits pretty level with the sportlines on now. dont know if you just do rears.
Old May 23, 2006 | 09:20 PM
DARK AGE 53's Avatar
thanks
So far I haven't seen a good write up on this mod, a good write up should include plenty of pics also for the first timer. I tell you what, I'm interested in helping someone do this mod and doing a good write at the same time, so pack you bags and head north and we'll get it done.
Old May 23, 2006 | 09:56 PM
uthinkimodd's Avatar
i'll probally get me some in about a month and i've got a great place to do the picture thing and write up but if somone wants to beat me to it be my guest
Old May 23, 2006 | 10:46 PM
Brandon97Z's Avatar
There's a pretty good write up on here somehwere just got search for it. For me installation took 2 hours and thats from when I pulled into my garage to when I pulled out. Rear took no joke maybe 20 minutes. Used hand tools for the rear and air gun for the fronts.
Old May 23, 2006 | 10:48 PM
A good write up would be a great addition to this forum, for those who are unsure about what it will take to do this mod it might be a good idea to wait for such a write up.
Off topic some what, Here's what I mean by a good write up ( sorry not a lowering spring install write up ) http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm , that's the kind of write up I'd like to see for the lowering springs.
Old May 23, 2006 | 11:08 PM
eazyasone23's Avatar
took me 3 hours to do the whole car. the front is more difficult and it helps if you have a couple extra hands around to help you around.
Old May 24, 2006 | 05:40 AM
Brandon97Z's Avatar
https://www.cobaltss.net/forums/suspension-67/spring-installation-18488/
Second post down is the write up i was talking about.
Old May 24, 2006 | 10:42 AM
GSoccer24's Avatar
did mine in an hour without a spring compressor
Old May 24, 2006 | 02:43 PM
You did all four from start to finish in an hour, lets hear some info on how you did that.
Old May 24, 2006 | 03:14 PM
Rusty's Avatar
holy crap, they made bolt on subframe connectors? i had mine welded on in my f-body
in any case, i'd also like to see a really detailed how-to for the springs with tons of pictures. i always get leary using a spring compressor. one slip and the spring just went through your face.
Old May 24, 2006 | 05:16 PM
That's one very important part of a good write when it comes to installing springs, as I was quoted in the write up.... Here I would like to add safety is #1 because dead guys can't work on cars.
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Sep 27, 2015 08:53 PM
