I can not find this rattle, can you?
Old Mar 11, 2011 | 02:46 PM
07BoostedG5's Avatar
I have a front end rattle, occurs only at low speeds, over minor bumps and its picky too, large speed bumps wont set it off, but a rough road at 15mph will.
It sounds like its coming from the front passenger side, I have replaced both Left and Right front end bushings as they were torn.
I can say I noticed the rattle when I removed the sportlines last year but I doubt a bad strut could make this sound.
Also if I jerk the steering wheel left and right at low speeds, I can hear a thud/rattle sound. I have had the car on jackstands numerous times trying to hunt this down.
I dont think endlinks can make this sound, So Im out of ideas and about to break down and just take it in for warranty work, but that is a last resort. Any ideas?
Pic of the bushings that were torn
Old Mar 11, 2011 | 04:22 PM
LS6Rally's Avatar
could be endlinks. sounds like it may also be the lower knuckle in the sterring column. mine makes a cluck at slow speeds as well. i haven t looked into the noise yet, but a few guys on here have had that issue
Old Mar 11, 2011 | 04:24 PM
RA040424's Avatar
Go out on your car and jump up and down on your drivers door sill and passenger door sill, if it clunks every time you jump then I bet this is your problem https://www.cobaltss.net/forums/prob...-worse-182520/
Old Mar 11, 2011 | 04:25 PM
CobaltVenomSS's Avatar
my dealer said it was the steering rack
https://www.cobaltss.net/forums/prob...ne-bad-242760/
Old Mar 11, 2011 | 06:43 PM
man, sounds like your issue^ marbles rattling is a good description, steering rack is pricey thou....
Old Mar 11, 2011 | 06:57 PM
I only have 35k on my car, perhaps the dealer will cover it.
Old Mar 11, 2011 | 07:01 PM
LS6Rally's Avatar
idk, youre our of the 3 years, but its worth a shot.
Old Mar 12, 2011 | 04:29 PM
gonzmexican's Avatar
i had the same issue, in fact mine is in the shop right now getting fixed..ended up needing new front struts, sway bar links and bumpers..i guess the noise was coming from a loose right sway bar (all covered under warrenty)
Old Mar 13, 2011 | 01:43 AM
I figured it out with the help of a friend, its the strut mount.
yet another reason why not to buy sportlines, I had them for 8k and they have destroyed both struts and a mount!
Old Mar 13, 2011 | 02:22 PM
LS6Rally's Avatar
dont blame it on sportlines. all springs do the same thing
Old Mar 13, 2011 | 03:03 PM
All springs after 8k? give me a break...Sportlines are trash.
Im on ss/tc springs and they are a lot better, Now Im pairing it with the fe5 struts.
dennis69
Oct 20, 2015 04:49 PM
agentirons
Oct 16, 2015 02:11 AM
jimbofug007
Oct 2, 2015 12:06 PM
Delta coupe
Sep 30, 2015 08:11 AM
Iceberg
Sep 28, 2015 01:31 PM
