Instalation question
Old Jul 31, 2010 | 10:32 AM
floydamus's Avatar
Ok so i got my sportlines in and im ready to install my only delima is the nut on the front struts. you have to be able to hold the strut shaft with a 45 torques bit and break the nut loose at the same time i think i can do it with a 13/16 sparkplug socket since that fits the nuts and has the head where a box end wrench can go on it. then i put a thandle torques through the socket to hold the shaft. wish i could find a nice offset socket set that uses liek a ratching wrech or special ratchet but i havent been able to yet. what did everyone else do?
Old Jul 31, 2010 | 11:26 AM
Cherry GT's Avatar
Loosen the nut while the car is sitting on the ground.
Impact works great, no need to hold the strut stud,
then raise the car and remove nut.
Old Jul 31, 2010 | 02:59 PM
floydamus's Avatar
tried this kinda was useing a breaking stick since im lackin the air tools im scared i might of broke a tab or something that keeps the shaft from spinning in the top plate
Old Jul 31, 2010 | 03:10 PM
08ShowbaltLS's Avatar
if u can find somebody with an impact wrench, it will make it really easy.
just installed springs on my car two days ago and one quick blip with the impact while holding the mount got it off. u compressed the spring already right?
Old Aug 4, 2010 | 11:19 PM
Nabes07SS's Avatar
When i had my struts in the spring compressor, i hit it with a 1/2 in impact gun. Came off fairly easy, got stuck twice cause the whole thing was spinning, so i just released some pressure on the spring whick put more tension on the bolt and it came right off. Repeat x2.
Old Aug 8, 2010 | 06:44 PM
floydamus's Avatar
yea i had it clamped i might just have to break down and get me a impact i got acces to a compressor
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
Bohb
Sep 27, 2015 09:11 PM
