Installing Coilovers?
Old Mar 22, 2009 | 07:00 PM
scotts2.0's Avatar
How difficult is it to adjust coilovers for a newb? Installing looks straight forward but how difficult (1-10) 10 being very hard, to adjust the camber, height, etc. Would a regular tire shops alignment be able to align without f'ing things up.
Old Mar 22, 2009 | 07:07 PM
crypticscifer's Avatar
I've never done it before, but would assume that each part is threaded count the threads for accuaracy, but I could be wrong.
Old Mar 22, 2009 | 08:08 PM
Maven's Avatar
A quality alignment shop can definitely align the car with coilovers(IE set camber and toe) but most will not mess with ride height without an extra charge, and few non race shops will have the scales, skills or experience to set proper ride heights and corner weights(almost noone does this, but its the right way to do it)
Old Mar 22, 2009 | 09:29 PM
CARLYLE's Avatar
^^^^^^^^^^what he said^^^^^^^^
Old Mar 23, 2009 | 08:53 PM
Smiles's Avatar
I would also like to know. How do you adjust the rear hight, with the spring and strut being seperate units?
Old Mar 23, 2009 | 09:45 PM
DaBuzzard's Avatar
Coilover has both spring and shock in the same unit....."Coil over shock" is where the name comes from. Rear looks like a hefty shock with a spring wrapped around it.
Old Mar 24, 2009 | 12:06 AM
CARLYLE's Avatar
Not on the cobalt the rear shock and spring are still seperate with coilovers but the spring does still have a height adjustment
Old Mar 24, 2009 | 09:12 AM
Maven's Avatar
Several of the inexpensive coil0ver kits have adjustable shock bodies too, which is annoying, because there are then 6 heigh adjustments that need to be made, not just 4.
Old Mar 24, 2009 | 10:44 AM
CARLYLE's Avatar
wow that would drive me nuts
Old Mar 24, 2009 | 11:18 AM
qwikredline's Avatar
And does not fit a Cobalt
Old Mar 24, 2009 | 06:55 PM
DaBuzzard's Avatar
Ah, nuts....busted! Guess that's why I come here, learn a few things along the way.
Never seen a set for the Cobalt, just assumed they would be the same as others I have seen.....guess I was wrong
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
