Installing front lowering springs...help
Old Aug 27, 2009 | 03:41 PM
harryresh's Avatar
how do you take the 2 bolts that hold the bottom of the strut to the A-arm? i took both nuts off and i cant get the 2 bolts out. are they threaded? i took a 15mm wrench to them but they wouldnt budge.
Old Aug 27, 2009 | 04:16 PM
tru2nrtt777's Avatar
NO DO NOT TWIST THEM!!!!!!!!!!!!!!!!
Take a hammer and thread the nut back on flush with the end of the bolt and knock it loose, they have straight splines holding them in place.
Old Aug 27, 2009 | 04:19 PM
XM15's Avatar
Yeah, just hammer them out. They are press fit.
Old Aug 27, 2009 | 04:42 PM
harryresh's Avatar
thanks guys...
Old Aug 27, 2009 | 04:50 PM
No problem, I used a brass punch and a hammer so it didnt damage my bolts but it doesnt really matter. Oh and when sliding the spindle back into them when youre putting struts back in put a floor jack under the ball joint and jack it up to where you need it.
Old Aug 27, 2009 | 08:30 PM
harryresh's Avatar
kool
i got the struts off and took an impact wrench to the bolt @ the top of the strut, but it wont loosen. am i doing something wrong?
Old Aug 27, 2009 | 09:27 PM
You have to jog it, the bolt at the top will spin with the nut, just keep jogging it on and off in 1-2 second bursts and it will come off, it may take a while though, to get that damn bolt off it took me about 20 minutes for the first and 15 for the second. If you move the dust sheild(plastic or rubber boot inside of the springs) you can watch it spin. My buddy has a 4th gen eclipse gt and when we did his we vice gripped the strut rod TAF so it wouldnt turn then wrenched the top bolt off since we didnt have air.
Old Aug 27, 2009 | 09:35 PM
snake890217's Avatar
QFT I had to take mine to the gas station to have him hit it with the impact wrench. He said that that type of strut was a pain.
Old Aug 27, 2009 | 09:39 PM
yeah our struts are ********, especially the base model since we start out with monstertrucks.
Old Aug 30, 2009 | 03:24 PM
harryresh's Avatar
thanks again guys. they r on and look great!
Old Aug 30, 2009 | 03:27 PM
No problem man.
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
